Question about Sharp AL-1641CS Laser Digital Copier
AL-1642CS GREEN LIGHT IS ON AND BLINKING 4-H
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Jul 24, 2008
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Error code h4 on sharp al-1642cs
I have a solution for this posted in the tips section. Just search for Sharp AL H4
Jan 16, 2010 | Sharp AL-1642CS Copier
ALARM H and 4 keep blinking -alternating
You have a defective fuser unit. H is for HEAT
Jun 25, 2009 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Locked up AL-1642CS with blinking Drum Light
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
H 4 flashing on the Sharp AL-1642CS
you have a problem in heater section------it may be bad thermistor -----defective heater lamp------blown thermal fuse------bad lamp connector----shut down the copier and leave it to cool down------clean all above from dirt and toner deposit and check-----lamp----fuse---thermistor by avometer in ohm range.
Apr 08, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
93 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
