Question about Sony VAIO VGN-FS640W Notebook
Laptop keyboard not working
My laptop keyboard letters r, i, u , caps lock and [ stopped working. I tried reinstalling the driver, cleaned the keyboard, and did a system restore.
    Genius:
  • 2,028 Answers
Random keys or a row of keys not working indicates that the keyboard is failing and needs replacing. Before replacing, you might try taking the keyboard off and cleaning the connection. A little dirt or corrosion built up might cause this, but most likely the keyboard has malfunctioned.
Posted on Jul 23, 2008
I have missing letters and numbers on my Sony Veio laptop keyboard when I type
Keyboard damage? Try a USB keyboard to check it before buying a new one.
Apr 22, 2014 | Sony Computers & Internet
Caps are on all the time
Press the
"caps lock" key once to take it off capital letters. If that doesn't work, get an external keyboard and plug it in and try it. That should do it.
Apr 08, 2014 | Compaq Presario CQ56-115DX Laptop
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
Keyboard only works when I hold down the shift key
the driver is corrupt. Uninstall and reinstall again. you must have the correct driver download from your supplier HP go to www8.hp.com
Use the antivirus, and malware for to see if there are some virus or malware.
God bless you
Oct 16, 2012 | HP Compaq nc6000 Notebook
My upper case S KEY WILLL only work if I have cap locks on. can you help me? ' Im using the MX5500 keyboard. thank you. Greg
Have you tried cleaning the keyboard, especially blowing it out with compressed air. Have you tried to use both shift button to see whether or not the problem is isolated to one shift button or both.Have you tried other letter with the same shift button that the letter "s" is having problems with. If this is islolated to just the letter "s" with the shift buttons then more than likely you will just have to use caps lock or buy another keyboard.
Nov 18, 2010 | Logitech MX5500 Keyboard/Mouse
Problem on start menu key..it press automatic without even touching it..when pressing any letter it shows the short cut key of the letter, example when you press letter E it shows my computer...
The issue is with the Toggle keys. Press the Caps lock and check if the same issue persists. Delete the files that are stored in %tmp%. reinstall the keyboard driver from device manager.
Jun 24, 2010 | Computers & Internet
The keyboard doesnt work
Either replace the keyboard or try and get the latest driver download for your keyboard
Aug 05, 2009 | Dell OptiPlex 360 Desktop Computer
Some buttons in my keyboard system are not functioning anymore
PLease reinstall the Keyboard Driver . Download from the official site go for Support and download
Apr 02, 2009 | ASUS m6n Notebook
Compaq presario c700 keyboard mulfunction
There are 2 common problems for this.
1. Something got stuck under the keyboard of your laptop. Food scraps or Dirt and Grime build-up due to sweaty palms or fingers clean the keyboard.
2.The Membrane on your keyboard that act as a switch cold be shorted due to wear and tear or heavy key presses. Have your keyboard replaced.
Other problems could be cracked board if you happen to lean or put heavy stuff over the keyboard and cracked ribbon connector.
Jan 21, 2009 | Compaq Presario 700 470024-192 Notebook
How do you unlock a few locked keys on my laptop
Can you tell me whether this is a bios power on password, a hard drive lock password, or a windows administrative operating system password? I'm assuming that it is asking for a password when you say "locked".
Jun 26, 2008 | Computers & Internet
Sony VAIO VGN-FS640W Notebook Logo
429 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
