Question about Acer Computers & Internet
My lapton is unable to pick up wireless connection
  • 300 Answers
This usually happens when the wireless card in the laptop has been turned off or disabled. If you locate the button on the laptop and it has been turned off, just move it to the on position.
If you are unable to locate the button, you can refer to http://www.rm.com/Support/TechnicalArticle.asp?cref=TEC242153 for some examples of what it looks like and where it may be on your laptop.
NOTE: Your exact model may not be listed, these are only examples. For an exact location you would need to refer to your manual for the laptop. Also, if you have to use a key combination to enable it, you will need to use the blue Function key (sometimes abbreviated Fn) on your keyboard in combination with the key referenced in the link to enable your wireless.
If that doest correct the issue, you will need to verified that the driver is enabled in windows. To do this, you can click Start > Run > type ncpa.cpl and press Enter. If you have Vista you can just click Start and type ncpa.cpl in the "Start Search" and press Enter. It will open Network Connections window. Look and see if your wireless connection say Enabled or Disabled. If disabled, right click the connection and choose Enable and that should correct your issue.
NOTE:
If you cant tell initially whether the connection is enabled or disabled you can right click the "Wireless Connection" and if it has Disable at the top of the menu, that means it's already enabled and vice versa.
Posted on Jul 23, 2008
    Problem Solver:
  • 17 Answers
Hello mull0566,
Having complete info available to me on model, operating system will help more - but IF this is a fairly new laptop....there may be a switch that you need to turn on to enable wireless.
If this does not answer your problem, post back with the make/model and operating system of your laptop and I will be more detailed.
Regards,
ChancesR
    Problem Solver:
  • 4 Answers
Make sure you have a wireless network card plugged in.
H0w do i connect my lapton to my epson printer wirelessly
Both your laptop and printer have to have wireless connectivity. Do you see your printer/did you setup your printer on your home network?
What maodel printer do you have?
Feb 27, 2015 | Epson Office Equipment & Supplies
Set a wireless connect between lapton and printer
You should check if your printer has an internet connection, if it does you can just plug it in and use it as a network printer.
Mar 21, 2014 | Brother MFC Office Equipment & Supplies
Keeps dropping wireless WPA-Personal internet connection
If it is not a router problem then you could try a wireless adaptor such as the Lapton N300 USB Adapter. This adapter will connect to all OS including Linux. $20 Max. I had a problem at home where a laptop would not connect at all and this adapter did the job. Maybe worth a try
Oct 28, 2013 | Microsoft Windows XP Home Edition
How do i connect my laptop to my printer
yo.......use usb cables, if old lapton the nuse parallel cables... if both cabels do not match with connection then buy a wireless printer
Jan 22, 2012 | Dell S2500 Printer
My aspire laptop is not connecting to wifi. it is saying wireless network connection 6 is not connected. wireless network unavailable. although i am using wifi in my another lapton just next to it
Simple things first. Make sure you did not accidentally bump the wifi switch to the off position. It will be on the front or side somewhere, probably a small slide switch. Moving laptops around, it is easyto bump it.
Aug 11, 2010 | Acer Aspire One PC Notebook
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Samsung R60 plus - not connecting to wireless network
Have you tried setting the wireless adapter settings to the default? Have you tried uninstalling the wireless adapter and re-installing it? Do you have a home network setup with an encryption key?
Sep 10, 2008 | Computers & Internet
My gateway lapton found a wireless connection to connect to, but once it is connected is not connecting to the internet
You can connect to a wireless router that isn't password secure, but if the router isn't configured to hand out ip addresses you can't get internet access. You need to know what address the router is on, and statically assign your laptop an address and gateway pointing to that router.
It's best to make friends with the neighbour and get the address.
Jul 30, 2008 | Computers & Internet
I would like to know how i can set up my computer to go wireless, i am already connected to sky broadband and have a wireless router, but i have to keep connecting the yellow cable to my laptop to get onto...
I would suggest a usb wireless adapter. These are getting less expensive and not as confining as pcmcia network cards.
link
You could look for these at wal-mart sams'club best buy circuit city staples, etc
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
