Question about Dishwashers
Have a Bosch shy56a05uc dishwasher that suddenly stopped working to a point. I believe it is related to the door latch switch, because I don't feel the door securely latch shut when I close it, and I also don't get any cycle lights or times registered on the LED readout. If I depress the on switch, the drain pump will start even with the door open, and, depending on how long I leave the switch on, water will start to fill in the dishwasher, open or not.
  • dtr1 Jul 24, 2008
    Hi Prince P,
    This dishwasher has the electronic timer and not the mechanical one. That's kind of why I'm leaning toward the latch mechanism, since it's got a microswitch in the circuitry. It's either that or the brain box and I'm hoping it's just the latch since it's not actually closing the way it used to.
    denny
  • Tnerb Brent Dec 22, 2008
    I have just encountered the EXACT same problem with the exact same model. Any ideas, anyone?
    Thanks
    Scholar:
  • 93 Answers
Does your dishwasher electronic control or mechanical timer? if mechanical timer, I encounter a similar problem n change the mechanical timer. that problem solved.
Prince P
Posted on Jul 23, 2008
  • Femi Omojogberun Jul 24, 2008
    Trip off the circut breaker to your dishwasher, or remove power plug and replace the latch switch and door gasket.this will solve the problem.
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
It stops in between washing the dishes and I have to push the door to run. I believe its loose contact. Can anybody throw some light how to fix this.
Check the door latch mount - maybe the screws have come loose or the posts for the screws are broken. There is usually a microswitch that detects whether the door is properly latched; you don't want to defeat it unless you don't mind water all over the floor. It is possible the switch is out of adjustment, but make sure the latch is good first.
May 02, 2011 | Dishwashers
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
KitchenAid KUDI10FL dishwasher- The door spring system broke and I repaired it, but now all of the sudden the dishwasher will not start. The door may have been dropped a couple of time before the spring...
Hi- It is possible that the door latch is not completely engaging. If the door dropped the hinges may have bent a little thus preventing a good contact with door switch. Try pressing and holding the door shut, hard, and pressing start. If that works then replace the latch assembly. It is also possible the membrane switch got rattled with the door falling, or a wire is grounding out somewhere. Hopefully it is just the latch. Hope this helps, good luck.
Sep 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Jan 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
432 people viewed this question
Top Dishwashers Experts
