Question about Refrigerators
Have Vestfrost Fridge/Freezer was shut off and defrosted.When turned on again fridge wont cool,freezer fine
  • danilyn Aug 02, 2008
    That is the exact same problem I am having. Home Depot where I bought it won't support or help. ATC Group who the warranty is with will not help either. The unit is considered a commercial unit even though it is designed to operate in a residential home and thus created a bigger problem because no regular appliance repair service will help only commercial repair services who do not want to help because they make bigger money with commercial jobs. I do not know what to do. Please help! I can't keep anything cold in the refrigerator part but the freezer seems to work just fine.
  • Anonymous Dec 07, 2008
    me too the back panel is cold enough but the middle and front are about 44 degrees. things are just rotting quickly. i defrosted it and there was ice on the back shelf which i removed. no helpl.
My freezer red lamp is on always what this mean?
Posted on Sep 06, 2010
  • Braggi Nov 30, 2010
    You have the super fast cool feature turned on. Turn it off. Switch in top panel next to freezer temp control. You must be using a lot of electricity.
    Only turn that on when you add something large you want to freeze quickly.
I have the sample problem, Dan in NJ Same exact problem as danilyn....ugh
Posted on Aug 07, 2008
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Bosch classixx fridge freezer. Freezer working fine, fridge not reaching a decent cool temperature. slighlty cool only.
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Nov 04, 2008 | Bosch Refrigerators
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Refrigerators Logo
796 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
