Question about Dell Inspiron 2200 Notebook
Dell Inspiron 2200
Function Key (Fn) - still operates volume and brightness with the other keys you press but does not show monitor on screen. Fn button does not work with the other "F" buttons. i liked being able to Fn and F3 for battery strength etc. Got a new keyboard, still the same. Can I reset something on the laptop?
  • st2malo Jul 24, 2008
    I restored to a previous date and it worked. Many thanks.
  • Anonymous Mar 24, 2014
    the fn key and f3 function key doesn't work in my Acer laptop
    Genius:
  • 2,028 Answers
You can try a system restore back to a point you remember it working, but most likely you will have to do a bios flash or an operating system repair with your recovery or operating system disc.
Posted on Jul 23, 2008
How to start computer on external monitor
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
May 10, 2013 | Dell Inspiron 1721 Notebook
I can't turn the fn key off
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it.
Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
Feb 06, 2013 | Dell Inspiron 1501 Notebook
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Can the dell inspiron m5030 work with a projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 12, 2011 | Dell Inspiron M5030 Laptop
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
Feb 01, 2011 | Dell Inspiron 6400 Notebook
Why is my screen sooooo bright? Over time, the screen has gotten very bright, I don't know how to fix the problem and would appreciate some help.
To adjust the brightness of LCD screen, hold down the FN key, repeatedly press the arrow keys to increase brightness. Or, hold down the FN key, repeatedly press the arrow keys to reduce the brightness.
Aug 13, 2010 | Dell Inspiron 2200 Notebook
I have Dell 1525 inspiron , earlier when u plug A/c power cable screen brightness will increase but now brightness is same power given or not(high(
PRESS fn AND UP ARROW KEY TO INCREASE THE BRIGHTNESS OF THE LAPTOP SCREEN.AND DOWN FOR REDUCING BRIGTNESS ALONG WITH fn KEY
YOU CAN CHANGE THE POWER SETTING TOO
WHICH FIXES THE BRIGHTNESS
WHEN IT IS ON BATTERY POWER OR IT IS IN A/C POWER.
FOR DETAILED SOLUTION PLEASE TELL ME YOUR OPERATING SYSTEM.
Dec 17, 2009 | ViewSonic E70f (White) 17 in.CRT...
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron monitor is hard to see, not as bright
boot and press F2 got to the menu comes up and go to display part in thath where you can increase the display brightness
or press Fn+F5 key while you are in ur OS
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Monitor comes on very dim, I can't see
click your "fn" key and then press the brightness key on the keyboard (it will be a blue or green "sun")
If this does not work, plug an external monitor to the laptop, if the screen is good on the monitor, your LCD display panel is shot.
Mar 21, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
226 people viewed this question
Alun Cox
