Question about GE Refrigerators
My landlord replaced my fridge with a GE Model GTS 17 BBSARWW, Serial # GRS 11920 How many wire shelves should the lower compartment have ? Mine only has 2 and I think there should be 3 Please advise
  • sixbees4u Jul 23, 2008
    Thanks for your prompt reply with the answer to my question
  • 93 Answers
17 cu ft ref. has 2 shelves only
Posted on Jul 23, 2008
Help to restore 1954 GE fridge door gasket. The gasket brackets are missing.
Hello Karen
Try somewhere like this
Refrigerator Parts
Gaskets for Antique or Vintage Refrigerators - YouTube
? 4:55
https://www.youtube.com/watch?v=39IRu2ATUA0
Jan 27, 2011 - Uploaded by AntiqueAppliances
... on two doors, no locks on the doors and not have the back cover. Do you have any pictures of this this ...
IMAGES
1954 GE fridge door gasket Google Search
Dec 01, 2017 | GE Refrigerators
Can't put shelves back in fridge.
I found the manual online. See if this page helps.
Nov 29, 2013 | GE PSH23PSRSV Stainless Steel Side by Side...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
The coils on my ge gss22wgpd bb side by side keep freezing up . IU can defrost them manually and the freezer and fridge work fine again.
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
This site has schematics of various appliances, including the model number you provided...
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS22WGPDBB&mfgModelNum=&fkMfgID=2
Your model appears very similar to mine - in the "Fresh Food Shelves" section of the above site, the sensor is diagram number 242. In the "Freezer Section", the sensors are diagram number 241 and 243.
Jul 28, 2009 | GE Refrigerators
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
Model GE TBX16SPCL Water dripping from vent at top of fridge compartment. Fridge and freezer regulating temp properly. No other issues. The dripping water is very cold. Thanks, Michael
Michael, I live in an apartment that has this model. I had a similar problem that the apartment maintenance man concluded was a clogged vent. I don't no precisely what he did to fix it but it involved opening the vent compartment and cleaning it out. Be sure to take everything off the shelves of the refrigerator before your start because it makes a mess. Good luck.
Apr 22, 2008 | GE Refrigerators
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
Freezing food in Frig especially lower compartments
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
Aug 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
