Question about Hannstar I-Inc TW-191D Monitor
I-INC cy199 Hello, I use to leave my monitor on and just let the computer shut it down. One day I shut it down with the botton on the monitor. And now it don`t come back on it just flashes yellow and blue, Any idea of what is wrong with it I see a lot of people with the same problem with this model monitor.
  • 1 more comment
  • Anonymous Sep 25, 2008
    Has anyone figured out how to get this fixed? I just bought one of these pieces of **** without doing any research and now i'm paying for it.
  • Anonymous Nov 15, 2008
    I cannot get the sound to work.
  • bretonlord Apr 23, 2009
    The I-INC CY199 does not display a picture and the LED shows an erratic flashing between blue, orange, and off.
  • 4 Answers
I have the exact same problem myself that just happened today. It apparently happens about a month or two after the warranty expires ;) I have 2 on my desk and one of them just stopped working. It is obviously a hardware problem and cannot be fixed without sending it back to the factory. They quote $65 for labor plus shipping. I might just go in the junk pile and I'll have to buy another.
Posted on Aug 15, 2008
Monitor wont power back on, Tried almost everything. Some days it will power up , sometimes is wont. If my timing is perfect and I plug the monitor into power cord at exact time I turn on computer it will...
Hello Adam,
You have a monitor with a power supply that is failing. The most likely cause is capacitors on the power supply board. We have an article posted on our site at: http://www.ccl-la.com/blog/index.php/capacitors/ That explains what they are and what you need to get to repair the board. If you don't want to do the repair yourself then we do offer a repair service, more information on this can be found at:http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please contact us thru our web site.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 14, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I-INC CY199D EEPROM failure
Hello, The EEPROM needs to be replaced and your problem will go away. I have one and replaced it in mine and it works fine now.
Jan 22, 2010 | Computers & Internet
I-inc CY199 monitor will not turn on
It sounds like you have a monitor with a common problem, we have repaired many Hanns-G monitors with this problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 10, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
My I-Inc CY199 is broken
check if the video card is ok if it is ok replace your vga cable
Jul 11, 2009 | Hannstar I-Inc TW-191D Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
I-INC CY199D lcd monitors will not turn on
The problem is the program for the graphics card is stored on a 16K serial eeprom which is used as a rom this can get corrupted which causes the problems you are experiancing.
I have repaired three of these monitors by re-flashing the eeprom with a program cloned from a working monitor all worked fine after refashing.
Now the bad news as the eeprom is used as a rom it is write protected on the board so the only way to program it is to remove it flash it with a valid program and then replace it easy if you are a surface mount expert.and have a serial eeprom programmer.
May 31, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dual monitors in XP Pro - HP Pavilion zd7000 laptop & I-Inc CY199 monitor
in that case u need a video hub, like : display booster. we call it a vga display booster. this may increase the quality of a picture. because when we attach any display unit, the image appears in two portion. it's gain is to low. to make it more sharp, monitor itself add some colour to that picture. the vga signal is fixed from inside of the monitor with resistance, so u can't make any variations in picture. that's why u guys need that VGA booster.
Jan 14, 2008 | Computers & Internet
Hannstar I-Inc TW-191D Monitor Logo
1,440 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
