Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
TV problem tow weeks ago my tv samsung hc-p4752w 47 in. start displaying a blue color shadow across my tv screen. what will be the solution for that?                                    Thank You
    Sergeant:
    Champion:
  • 223 Answers
It sounds like there is a fault on the chroma panel of some kind.
Posted on Oct 01, 2008
My samsung 47 in projrction tv has blue gosting or a blue double
Thats usually related to the convergence Ics and the 3.9 ohm resistors needing replacement.
Jan 23, 2010 | Samsung HC-P4752W 47" Rear Projection...
I have a blue screen that displays not supported mode.
CHECK UR SETTINGS ON THE GAME CONSOLE ,,YOU CAN ONLY USE THE VIEWING MODES THAT ARE SUPORTED BY UR TV
Apr 14, 2009 | Samsung HC-P4752W 47" Rear Projection...
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Problem with hc-p4752w
Jan 10, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Blurred
im sorry for this not being a solution, but I have the exact same issue Jose. It just happened 3 days ago. When I run auto focus it says check factory default settings. Will replacing the 2 CI's help cure this problem.
Jul 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Henry  Thomas
Henry Thomas
