1995 Ford Mustang Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blower motor not working. fuses appear to be ok. was working fine yesterday. any ideas?
Anonymous
Level 3:
Master:
  • Master 411 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Master:
Answers
411
Questions
0
Helped
109299
Points
1240
Check fuses under hood loose wire at blower under hood passenger side firewall
Anonymous
Level 2:
New Friend:
  • Expert 46 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
14145
Points
137
Test the blower motor, turn on the switch and then with a test light conect it something that is grounded. Check for power at the harness, then connect the test light to the power side of the battery and test for grown at the harness if you have power and and ground replace the blower.
My 2004 impala heater blower stopped working but was working fine yesterday but no heat today?
Check fuse first. If ok then likely speed control module or blower motor itself is faulty.
1helpful
Blower Motor on 2000 Saturn SL
The blower motor is connected to a termic switch, when the motor is fine and fuse is ok, is the switch that must be replaced.
Ensure the fuse is ok first.
Blower Motor Not Working properly
check "amp" at the blower motor! if the "amp" its to high , you better replace the blower motor! It will damge your blower control module soon also!!
Blower Motor/Fuse
On Nissan vehicles, the blower motor gets power from the fuse box, and the resistor and fan speed control provide the ground circuit.
So you should be able to ground the motor and make it run if you have power going to it. Then you would need to check the resistor and fan switch. The high setting bypasses the resistor.
3helpful
2004 Grand Caravan Front blower will not come on.
Check owners manual for location of heater blower motor front,check with a test light,if it's good locate blower motor under glove box and test the two wires for power when switch is turned on,if power is present motor needs changed.if no power check blower motor resister.
2answers
A/c/heater bower stopped working 2004 Dodge Dakota
Check Your heater blower motor resisto located somewhere on the heater box.
AC on Caravan
you have either a bad blower motor resister or a bad blower motor. the resister is located in the heater box close to the blower motor.
Fan quit on 87 celebrity, heat ac, etc.. fuse ok ????
Hi
Check for bad connection at heater resistor or try tapping heater motor lightly
with ignition switch on and heater switch on. Could be heater switch connection.
I have a 2007 ford five hundrd the blower stoppe working, all fuses have been checked and are fine. Any ideas
Fuse 35 (40Amp) Front A/C blower motor, this is under the hood in the power distribution box, is it ok? if it is, the most likely problem is either the AC blower speed control module or the blower motor itself, jump 12 volts to the blower and see if it runs, if it does and the fuse is ok, replace the blower speed control.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
