Question about Kyocera Mita FS-1920 Laser Printer
Problems with Kyocera Mita FS-1920
Excuse me for my english...
I'm having trouble with my printer Kyocera FS-1920. When printing documents with paper size different from those defined in the printer does not print duplex from Tray 1 ... I can do?
  • johangelg Jul 23, 2008
    Thank you for a quick response
  • Kyocera Mita Master
  • 2,794 Answers
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Posted on Jul 23, 2008
Printing blank paper
check if the developer is opened before fixing open two screws on the top cover and clean the underlying glass screen which snap the image
Oct 17, 2012 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
My kyocera fs mita 1920 some dose not print or the message of add tonner come out while tonner was their why it do that?
remove the toner ... shake it well and re fix it and check ..... remove the drum unit and clean it ........ for more details please post your comment
Dec 29, 2009 | Kyocera Mita FS-1920 Laser Printer
On my kyocera fs-1920 printer.. it shows a light where the exclamation mark is (!) What does that mean?
if its flashing then the machine is warming up.. if its lit then there is a paper jam or a tray or door is open...
Dec 08, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Aug 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Network printing ok but word documents,e-mails etc problem
please make sure that the printer properties and printing preferences (right click the printer in the printer(&faxes) folder the paper sizes are set to match the printer,
then make sure that the documents you are printing are the same size.
on the kyocera printers you can also set a setting to override A4/LT
press: MENU, SCROLL DOWN, PAPER HANDLING > SCROLL DOWN, OVER RIDE A4/LT > ON, ENTER.
hope this helps.
Dec 15, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
333 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
