Question about Hatco C 24 Compact Electric Booster Water Heater
Booster heater quits heating water after a few minutes of use and you must hit reset button to get it to work again. What would be causing this? For Hatco C36208 Booster Heater 3 phase
    Sniper:
  • 68 Answers
#1 I would check that you actually have 3 phases connected. #2 I would also check the ground. There could be a loose ground, or depending on the installation, the ground could be defeated by rubber washers in flex lines. Fix this by running a wire from the casing of the water heater to the pipe, bypassing the flex lines.
#3 Replace the thermastat. The thermastat has the reset button on it.
#'s 1 & 2 are very minimal in cost. #3 is still affordable.
Please rate this solution
Posted on Jul 29, 2008
My line water heater turns off after a few minutes
if u are hitting the red button and it is a heat pump hot water system it means that the unit is going out on high pressure ( the red button is a high pressure manual reset button) this could be caused by a few things could be over charged ( but unlikely if no one has touched it recently) a solenoid isnt opening or there is a blockage in one of the TX valves. if the button u are pushing isnt in the pipe work and it is on the compressor it could be an over temp switch on the compressor ( unit could be short of gas) just need a little more info to pin point the problem.
May 21, 2014 | Stiebel Eltron Water Heaters
Water does not stay hot
Had this trouble with a condensing boiler,water pressure was too low, also if thereis an adjustable stat try turning this up ?
Jan 26, 2013 | Rinnai RU98i-N Interior Natural Gas...
My "clean" light flashes even
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 30, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
MDB6160AWW - flashing lights after hitting the normal cycle: Clean and Heated Dry buttons flash. What is this code telling me? Keith
Hi
These blinking lights indicates an issue with heater circuit, door switch or wash pump. Please reset the power to the dishwasher and after, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 18, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
May 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
A2 error on Bosch tankless water heater
  1. Check continuity of the flue gas limiter (see Fig. 63, page 46 of manual). Go to steps two and three to determine air box temperature sensor fault and replace it.
  2. Check for flue gas leakage around the top and bottom seals of heat exchanger as well as the viewing window.
  3. Check that venting is within specifications (see Section 3.3 of manual). Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
  4. Check that flue gas limiter connector and spade connections are secure.
  5. Unplug heater and check the two main plug connections inside the control board.
Jan 22, 2009 | Bosch & Tankless LP Hot Water Heater
Hatco C 24 Compact Electric Booster Water Heater Logo
369 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
