Question about Dryers
I tryed fixing my kenmore dryer but the belt is loose and i found what looks like a half moon type of pully
  • 5,911 Answers
If you are talking about the idler pulley, which isn't a pulley at all, it is highly recommended that you replace it with a standard idler pulley. This was orginally designed as an attempt to save money by the manufacturer, but turned out to cause premature belt wear in many cases. A replacement idler assembly (part number 691366) is a better option. As far as reinstalling the dryer belt, you can find diagrams at under the "Special Features" section under "Repair Help". There is a link for "Dryer Belt Diagrams". Your dryer is manufactured by Whirlpool. Your diagram will be either "H" or "K" depending on how the dryer is constructed. If your dryer has a removeable back panel, use "H". If dryer does not have a removeable back panel, use "K". HINT: Most dryers with removeable backs have the lint screen on the top of the dryer. If you need additional assistance, please post back and let me know. I hope this helps you.
Posted on Jul 23, 2008
  • Jeff Rockwell
    Jeff Rockwell Jul 23, 2008
    PS The replacement idler pulley can be found at if you wish to order on line. Just type in the part number I provided. Just make sure you pay attention to the item description. That parts costs about $13. If you do not wish to order on line the website also provides a service where you can perform a search by local stores based on your zip code.
I have a Kenmore Dryer Model number 66902691 that has a burning smell when it is running. All lint was just cleaned out of it, but it is still smelling!
This might be caused by a seized idealer pully, located on the bottom of the dryer drum. A belt wrapes around the drum and across the idealer pully and then on the motor pully. If the idealer is not turning freely, it creates friction and eventually burns the belt in half.
Hope this helps
Apr 29, 2011 | Washing Machines
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
Model# 110.72602101 Kenmore Dryer I had ordered the belt replacement but the instructions show an Idler Pully but I don't seem to have the wheel that goes on it. Not sure how this belt is to be...
you must have the older style pulley that's all metal with no wheel.rap the belt around the drum,on the side where the pulley is pinch the belt together stick it under the half moon part of your metal pulley and stick the looped end around the motor shaft,if i were you i'd call the place where you bought the belt from give them the model number and order a belt kit,you get the belt,the rollers and the pulley with the wheel not that metal **** piece and replace it,you get all those parts for short money,cheaper than buying them seperate or use it for now until it starts getting noisy.let me know how you make out and if you need anymore help let me know
Aug 05, 2010 | Kenmore 60172 Electric Commercial Dryer
Cant install my belt back on my idler pully on my kenmore 80 series dryer . the idler pully i have is a piece of metal below but it does not open up so the belt will go through. i am missing something but...
Howdy: Check for the bolts that hold the pully on. Loosen the bolts and the pully should stat to open. You may have to put on the belt then install the pully. Look close at it. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Is there an adjustment on the kenmore 4179172000
The thing that you should now when taking on a repair on a "skyscraper" like thses, is that they are a monster to repair!! There is no "adjustment". The manufacturer (Whirlpool from the looks of your Model #) has a "fixed" tension on these units so they cannot be tampered with. You would need to purchase a repair manual that matches the unit you have to take you step-by-step. Plus, you can't just go by the size. The belt has to be ABSOLUTELY EXACT as the original. Did you get the belt from Sears or a third-party?
Dec 05, 2009 | Kenmore 62602 Electric Dryer
Can't get Dryer Belt on Kenmore Dryer
Not sure if your dryer is the same, but here's a diagram that may help.
Dec 12, 2008 | Roper RAS6233KQ Top Load Washer
Dryer squelles
the sound is thr support rollers or the idler pully, the support rollers located under the drum to the back the pully holds the belt tight. look for meatle shavings or rust dust on rollers.
Jul 14, 2008 | Maytag Neptune MDE4000 Electric Dryer
Makes squeaking noise after running for about 10 minutes
you can check a lot of things. the motor itself, the rollers on the back, and the main bearing at the center of the drum. you can apply any lubricants to all of those rolling parts.
Feb 12, 2008 | Kenmore 84152 Electric Dryer
Kenmore dryer
The pully fits in some groves at the bottom of the motor shaft , the pic should help 9b7b31e.gif
Oct 13, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
109 people viewed this question
Top Dryers Experts
