If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on. 3. Make sure PS3 is connected via correct cable. 4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
if there is no signal, then one of the cables or wires could be loose, check that all of the cables/wires are connected properly. Then if still not working try changing the av/ext channel that you have it on.
if your PS3 is closer than 20 feet from your router, then its unlikely to be your signal strength. However, Wireless connections tend to "poll" their connected hardware. What I mean by taht is.... The router sends out a signal, just to check and make sure all the peripherals are still there. I dunno about PS3 yet, cos I havent tried to game online, but I am an avid PC online gamer, my pc is within 5 feet of my router and Ive switched back to LAN cable to play. I was experiencing periodic "lag"... due to that polling effect. Try using the LAN cable and see if that makes a difference ( I dont know how many Ethernet RJ45 connections a Netgear has, ... if it only has one, you may need to connect a "switch" )
