Question about Ovens
Whirlpool oven stopped working (Whirlpool accubake oven - GR450LXH)
My girlfriend recently tried to clean the heating element on our oven (Whirlpool accubake oven - GR450LXH) and when she turned it on, the bottom heating element glowed like the sun and fell apart. The upper element worked fine. I recently replaced the lower element, and now neither element works. It sparked a little bit during the installation. Anyone know what needs to be replaced?
  • 17 Answers
SOURCE: The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Posted on Jul 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Posted on Sep 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: jenn-air ww30430w dual oven, lower oven, lower
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Posted on Jan 03, 2010
heatman101
  • 43501 Answers
SOURCE: Upper oven heating elements will not engage.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
  • 14 Answers
SOURCE: after the electricity went off to the house for a
First, you need to check the 2 circuit breakers. One goes to the control board and the other one goes to the heating elements. If the heating elements still do not work, you would need to check them for continuity.
http://www.appliancepartspros.com/ http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/
Posted on Feb 14, 2011
When baking in whirlpool accubake electric stove model GR475LXMS only the broiler works not bottom element what could be wrong?
The element could be open or the thermostat for the oven could be stopping power from reaching the element
Oct 17, 2016 | Whirlpool Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool accubake RBS275PDB6 will not heat up to preset temp
I am assuming the lower element is not working well. Go ahead and replace it. But first , go turn your breaker off to the oven and then back on. Often times it can be tripped but not showing due to the other poles not being tripped. The lower element is the cheaper one also.
Feb 24, 2013 | Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
We've a Whirlpool Gold Accubake System (electric). Yesterday, the oven was working fine, we did a cleaning and today when we went to use it and it would not heat up. Is there a way to determine if the...
its not uncommon to have this happen. it may have overheated . causing the hi limit on the back of oven to fail, that is what you need to ck . and repl if you find it to be bad. **** .. if your want to ck the element then when the back is off range . you can ck the two elem with a ohm meter . . ****
Dec 25, 2009 | Ovens
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
374 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
