Question about HP Pavilion zd8000 Notebook
Laptop will not power on
Power light on from power supply on unit but no power to laptop
    Scholar:
  • 67 Answers
Shutdown the laptop
Unplug the power supply
Remove the battery
Plugin the power supply
Turn it on
If it works then the battery is shot and needs to be replaced
Still doesn't come on replace the power supply
If you replaced the power supply and it still doesn't turn on, then the you'll need to get it service as the motherboard would have to be replaced.
Posted on Jul 23, 2008
Dead toshiba satellite laptop
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Toshiba Sattelite A105-S2071 Notebook
My sony vaio will not turn on
Either the power supply is bad (has died) or the power unit in your laptop is bad. Try another power supply if possible. If not you'll need to open up your computer and replace the power supply unit.
Apr 07, 2012 | Sony VAIO GRX550 Notebook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My laptops screen does not come on even though the unit powers up,i have tried another screen,and tried using external monitor,neither worked,the lights by power button also don;t light.
Did you check the power supply? They go bad and if you get no power, nothing else will work. You can check the power supply by plugging the unit into an outlet and then using a volt-ohm meter measuring the voltage at the cylinder which normally plugs into the computer. If there is no voltage (DC) present, then the supply is bad. You can get a replacement online or at the place you purchased the unit.
Feb 01, 2010 | Computers & Internet
I have a toshiba satellite A135-S4677 it doesnt start at all i have it plug in and no light from the laptop just the light from the power cord please help
the adaptor may be out it may not be supplying power to the laptop power supply circuit
or
the power unit circuit in the notebook may be out
or
the motherboard may be down...
only tech shop can fix it...
Jan 21, 2010 | Toshiba Satellite A135-S4527 Notebook
MDG Laptop will not power up
It sounds like you are using an inadequet power supply. Check it for low voltage and/or amps.
Feb 20, 2009 | Computers & Internet
Benq laptop power unit 'short'?
The fact that the LED light on the power supply tells me that its receiving power, look where the AC adapter goes and check the pin to see if it is loose, this sounds like feedback from the computer causing the power supply light to dim or go out
let me know how you get on
Dec 02, 2008 | Computers & Internet
Notebook wont boot up
it may be power supply unit problem , if it is in warranty contact the authorized service center
Jul 13, 2008 | HP Compaq nx6110 PC Laptop
Won't boot up
Can you give a little more information? Did the Laptop Fall? What Color is the light that blinks? Amber or Green?
So far it Sounds to me that you Power Supply is Dead or Bad and or not charging the Battery....
First Check the battery status light?
Is the Power Supply Light (Lite). you might want to try removing the battery and using only the Power supply!
Jan 15, 2008 | Dell Inspiron 4150 Notebook
Error 0271
Sounds like it is asking for the power supply to be plugged in before it can start, which indicates a bad Battery, if you are allready plugging in the power supply unit, you may also have a bad or wrong power supply unit,(check that it is set too the correct voltage setting for your country too either 120V or 240V.) Possibly you know someone with the same working laptop so this can be verified by using thier working Battery/powersupply unit or as an alternative can both your battery and power supply unit be taken to a computer or electronics outlet store for simple bench testing before deciding on replacement. Lastly it may be a powersave mode or setting that has been activated before the last shutdown in this case press and hold the power on switch down, until all the lights go out. Leave it turned off for 30 seconds and restart. Press the esc or delete button on startup (before any screen info comes up)and adjust the power save mode setting in this systems bios.
May 17, 2007 | IBM ThinkPad T21 Notebook
HP Pavilion zd8000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
