Question about Sanyo DRW-500 DVD Recorder
Sanyo DRW-500 Home DVd Player/Recorder
I have owned this unit for four years and it has worked well until the last year when the motor spin-up started failing in the drive. It finally died altogether and I attempted to repair the NEC ND-1100A DVD-RW drive inside the unit but the motor is completely gone. I attempted to replace the drive with an Optorite DD0201 I have but the unit hardware refused to recognize the drive.
Since the NEC ND-1100A is no longer available except through rebuilds that cost more than the unit is worth, are there any other drives that will work with this unit so I can get it back online again?
  • stevied6 Oct 31, 2008
    I solved my own problem and it took a lot of tinkering but in the end the solution was so simple I didn't think of it until last: You can put ANY DVD-RW replacement drive in the unit as long as you remove the factory set jumper on the back of the unit from CS (Cable Select) to MS (Master) and any unit will work perfectly in the DRW500. Apparently the chip set is pretty generic for interface with any DVD-RW on the market.
    So all you folks who own this recorder can extend the life of it indefinitely as long as the chip set and the power supply will last.
    In truth, the cheap and obscure Optorite DD0201 DVD-RW works much better and smoother than the original NEC ND-1100A which is a total piece of ca-ca that doesn't even maintain firmware upgrades anywhere on the net. I pulled it from an old computer that had bit the dust and a customer left it behind after I built them a new unit. I recoomend that anyone who still has and uses the Sanyo DRW500 get rid of the NEC internal drive and replace it with almost any of the newer and cheaper units available on the market from $29.95 and up. The NEC was hinky from the beginning, to say the least, and it never performed as well as the cheap Optorite I replaced it with. I found the problem with the NEC drive which was unrepairable due to a defective bus connector that controlled the read/write laser head. It was so brittle that heat eventually caused it to fracture and fixing it would have been a bigger pain than just replacing the whole unit so I figured that by tinkering with it I might find a solution and I did.
    So don't throw that old DRW500 unit away when you can fix it cheaply and use it for many years to come.
    The only down-side is that many DVD-RW son't have the disc slide drawer mounted as low as the NEC did so you might not be able to use the original drawer cover that was used on the NEC because most are too high up and caused the unit to jam when the door closes. Other than that I'm very happy I got the old girl working again!!
My drw-500 wont read any disc why its say NO DISC please help
Posted on Jul 31, 2008
Sanyo drw-500 dvd recorder will not recognize channels from antenna in setup
Have you set the Sanyo to "antenna" or to "cable" ?
If you've tried one setting, try the other.
Apr 16, 2014 | Sanyo DRW-500 DVD Recorder
Record mode doesn't work. Information is disrupted. play back is fine have not tried to fix
It could have some garbage, in the processor do to a small power surge, and if you leave it unplug for 40Min., from the wall, it should reset back to normal.
Feb 21, 2011 | Sanyo DRW-500 DVD Recorder
Has trouble recognizing a new blank DVD
try a cleaning disk, if that doesn't help, goto the manufacturers site and check for a firmware update in the support and drivers section
Jun 15, 2009 | Sanyo DRW-500 DVD Recorder
Need manual for drw-1000 DVD recorder
hi!u can get the manual from this link
http://www.retrevo.com/s/+Sanyo++DRW-1000+DVD+Recorder?sub.x=0&sub.y=0
if the link doesnt work,please make a free account at retrevo.com and download the manual
hope it helps!
Nov 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo DVD recorder DVR-DX600
I don't know about where you guys are but when I went on to www.sanyo.co.nz and went into support and insturction manual searched DVD recorder it came up with english manuals for all their DVD recorders, just cick on the one you need
Jun 09, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo drw-500
try cleaning the lens of your dvd if that does not work have a tech look at your dvd it could be having a problem in the recording circuit which is controlled by a chip.good luck
Jan 06, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DRW 500 DVD RECORDER
check partstore.com for a manual on your dvd recorder.good luck
Sep 08, 2007 | Sanyo DRW-500 DVD Recorder
Finalizing disc
Try finalizing on the unit you have now. or find some one with a Magnavox to do it on or even a PC
Jul 30, 2007 | Sanyo DRW-500 DVD Recorder
Dvd recorder, pc, dcd player
I take it this is a recorder only model not one with hard drive. I guess it will be line out from PC to line in on the recorder The recorder probably has RCA red/white cords So you will need a 3.5mm stereo jack to RCA converter this will work on the PC either way line out for trans to DVD line in for form DVD to PC
Jun 23, 2007 | Sanyo DRW-500 DVD Recorder
Sanyo DRW-500 DVD Recorder Logo
216 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
