Question about Sony Cyber-shot DSC-W30 Digital Camera
Flashing yellow light beside veiwfinder.
The camera turns on fine and will take pictures, yet you can't veiw them on the camera itself. The directionial pad dosn't work nor the play button to view the photos. Also you can only set it on 3 modes movie, soft shot, and auto, everything eles on that wheel does not register to the camera. It is flashing a yellow light next to the veiw finder, and in the lcd the flash symbol is going also E:91:01
  • 477 Answers
You error message is your flash circuit which need to be replaced they run around 30 plus dollars for the part or it could be the main board just depends. With out diagnosis it it is hard to really tell.
Posted on Jul 23, 2008
My camera is making flashing on some of my pictures after i take them and veiw them
you might be seeing your cameras way of showing you that the highlights in your picture are "blown out" or way over exposed. try using a smaller f stop and flash.
Aug 13, 2011 | Nikon Cameras
My camera will turn on, then when screen is on for about 5 seconds, the screen turns off, and the red light beside the SIM card slot starts flashing.
Take out memory card form camera and turn it On, if camera stays On and shows normal view that means memory card is bad and causing problem.
Put new memory card in camera and take pictures.
Nov 04, 2010 | Sony Cybershot DSCW370 Digital Camera
I have no image in the viewfinder on a canon S2 IS but the lcd display works and it seems to work fine otherwise. What are the likely causes?
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Jun 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Mar 21, 2009 | Canon PowerShot S2 IS Digital Camera
Veiw finder is blurred wen i look through it closeley,but far away its fine pls help
Under the veiwfinders eye peice is a small switch! look in veiw finder and adjust switch to focus and it will clear up for you!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Sony CCD-TRV238E Camcorder
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Lcd black while in picture taking mode
Your ccd appears to be bad. Canon USA will repair this for free. Go here for details. They will send you 2 emails. One with the UPS label and another with info sheets to be sent with the defective camera
May 28, 2008 | Canon PowerShot A75 Digital Camera
Sony N2 veiwfinder problem!
Can you see Shadow images[ indicating back light failure]
or Nothing at all[ Indication main circuit board or connector problem
If you are still in warranty then send it back to seller.
You could try gently squeezing the case below the screen to see if there is a chance of a re connection.
Also check out Sony support in case there is an issue with that model
Failing that it is a repair job
Prbably nearly as expensive as simply junking it and start over
May 07, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
185 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
