Question about Epson AcuLaser C900 Printer
I dont know how...
How to run AdjProg.Exe.? is there any icon im going to click.? ive already download the c90.rar file...please help... Thankzzz.... : )
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Posted on Aug 24, 2008
    Problem Solver:
  • 8 Answers
Actually this is just an opinion regarding epson C90. I defintely agree with hanshufkens@yahoo.com. Epson C90 is a *******!!! printer. My experience indicates that this printer is loaded with TAMPER PROTECTION FIRMWARE so that users will visit epson service centers and PAY MORE. When the firmware senses that it is being tampered with, it will issue "fatal error". After series of attempts, it will just shut the printer off completely and you can never turn it on again just like what happened to my printer. I WILL NEVER BUY AN EPSON PRINTER again.
Posted on Nov 08, 2008
Adjprog.exe
You can get Adjprog.exe from here
http://www.imprek.com.ar/reseteadores/tx125_t25_tx135.rar
Solucionado AdjProg exe para epson tx 135 alguien lo tiene Impresoras...
Sep 15, 2015 | Office Equipment & Supplies
How do I get software to install cyber pix s-550v camera as web
Please click on the link I provide, scroll to the very bottom, download the 2 .rar files. Once downloaded click http://www.rarlab.com/rar/wrar401.exe to download winrar. Install winrar. then right click on the first rar file you downloaded from    http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital+Camera/Others/Mercury_CyberPix_S-550V_driver and then choose "Extract to Driver". It will start extracting, then ask for part2. Click on browse, and then choose the part2 file. Once it is all extracted, open the folder it extracted to. Run the Setup file, and once complete you should be able to use the camera as a webcam. Let me know if you need more help. And if I helped fix this problem please make sure you mark this problem as solved.
Jun 30, 2011 | Cameras
Want to know how to reset my epson R390 printer
Hi!
Download Printer Resetter here: http://www.mediafire.com/?3lbjlqmsqa9
1. Turn on the printer 2. Set the pc date setting to 1 January 2007 3. Adjprog.exe run from the extract of a folder (or locate the file or application. Exe and run it) 4. Click accept 5. Click on the particular mode adjustment 6. Go to interview Then select waste ink pad counter then click ok 7. Click "button box" until it is done then click "initialization" button and then click "finish button" 8. Turn off the printer for 5secs then turn again 9. Set the date today.
Cheers!
Feb 25, 2011 | Epson Stylus Photo R390 InkJet Printer
HOW TO FIX GTA SAN ANDREAS ERROR REPORT
do this. first download qtorrent 2.0 from this link: http://www.filehippo.com/download_utorrent/download/1487bd182fb59e046843bca1987bb2f5/ when you do, go here: http://btjunkie.org/torrent/GTA-SAN-ANDREAS-NOCD-CRACK/449595af25b9576fcc391828d822514571aa13c39b58 and click download torrent. some window will popup after clicking donload torrent. choose the location of download, and click ok. when it finishes downloading, go to location of download and copy the file that has .exe on the end, to the C:\Program Files\Rockstar Games\GTA San Andreas. when you do, it will say that you already have that file, but just click to replace the existing one with the downloaded one. make a shortcut of that new gta sa launcher, and there you go. from now on double click that new one to play without problems
May 25, 2010 | Rockstar Games Grand Theft Auto: San...
Parts inside your printer are at the end of their service life. See your printer documentation. 1. Download Adjustment Program for Epson C90 2. Change your PC Date to Jul 24 2007 3. Delete the folder...
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Apr 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Need to open rar folder
download winrar from one of these ...
if your windows is 32bit
http://www.rarlab.com/rar/wrar391b1.exe
if your windows is 64bit
http://www.rarlab.com/rar/winrar-x64-391b1.exe
install winrar
then go where the rar file folder is.. right click on the rar, and select 'extract to ' and then double click on the folder which would get created...
Good luck !
Nov 24, 2009 | Sony Video Game Consoles & Games
How to change windows themes and icons?
You will need a 3rd party program to install custom themes in XP.
StyleXP and Windowsblinds are just a couple you might look into.
Mar 19, 2009 | Microsoft Windows XP Professional
Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
No audio
If you are having Winodws XP installed in your Notebook, try the steps listed below :
Click on Start Menu and then on Run. Type Services.msc in the search field.
The services window opens up. Locate the service Winodws Audio from the list.
Double click this service and select the Startup Type as Automatic and go to the Recovery tab.
Select Restart the Service for First failure, Second failure and Subsequent failures.
Click on OK to save the settings changed and close the window.
If the service is already running or the Automatic is already selected, we may have to reinstall the Drivers by downloading them from HP..
First, as your Notebook is installed with HD Audio, you need to download and install the Microsoft UAA Drivers which are available from the link below :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
Save the file to the Notebook, double click on the file once it is completed to install.
Now, download the Audio Drivers for the Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
If you are having Vista in your Notebook, you can try reinstalling the Audio Drivers in the Notebook which are available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Download and save the file in the Notebook and double click once it is saved.
Hope this works....
Aug 07, 2008 | HP Pavilion dv6000z Notebook
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
755 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
