Question about InFocus IN72 Multimedia Projector
In Focus IN72
It's less than 2 years old with 855 hours.
Heats up after about 8 minutes. Last time it had a littel smoke so I quickly turned it off. What coud be wrong and who can fix it at a reaonable cost?
  • 23 Answers
The capacitor that is blown wouldnot be a 150V but a 450V. Dannol, I think you should really double check that as you most probably could be wrong or it most probably is a typo error.
The correct capacitor is a 104K450 NIS T83. 100nf (0.1uf), 10% tolerance and 450V rad polyester type.
Posted on May 29, 2010
    Problem Solver:
  • 11 Answers
Heat sensor is gone, it seems. try avalontc.com
Posted on Aug 06, 2008
When my projector started doing that, it finally blew altogether. After I opened it, I found it was a blown capacitor on the mainboard. I was able to fix it once but used the wrong capacitor. If you have any soldering skills, you can open the projector and determine if it is a blown capacitor. If it is, the little red square capacitor is a 0.1mF +/- 10% tolerance, 150V capacitor. Hope that helps.
Posted on Aug 28, 2008
The oil that is in it, is poulan, chain, and bar 30 weight, can I drain, or flush,engine
I usually just drain the oil. Bar and chain oil is thinner than normal SAE 30. If the engine is not seized, then I would suggest using a 15W-40 oil if you are in a warm climate area. These air cooled engines get hot quickly and that will cause the oil to thin more quickly and become less effective. Using the 15W-40 may cause hard starting at lower temperatures. Depending on how long the engine ran with that oil has a lot to do with the "reliability" of the engine. If it was smoking the last time you used it, then yes the engine needs to be reworked (new rings and valve seals in particular). If it wasn't smoking, I would run it with the heavier oil until it just won't turn anymore. These little engines are pretty tough. If the mower is less than 2 years old, then I would put the manufacturer's recommended oil back in it. Don't be too concerned if all of the old oil doesn't drain. Just change it again around mid-season.
Apr 23, 2015 | Garden
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
Troy bilt self propelled mower overheats
Check oil level . Dump out old oil and fill with new 30w oil.
Sep 24, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Heats up and shuts off is it worth fixing 20 year old projection tv
Yes,if the tv is barely used each day.Like tv used only 2 or 3 hours a day only.If the tv is used alot like 6 or 8 hurs every day for the last 20 years.Than u should replaced the tv because the tv CRT-tv tube is already reach it life time cycles.
Apr 19, 2011 | Hitachi 57F500 57" Rear Projection...
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
ET70115C $379
http://www.1000bulbs.com/product/3391/ELEC-ET70115C.html
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
http://www.amazon.com/Intermatic-EH10-Electronic-Heater-Indoor/dp/B000GHIPOA
Intermatic ET1105C $96
http://www.amazon.com/Intermatic-ET1105C-Hour-Electronic-Switch/dp/B002X1FYWI
Intermatic ET101 $101
http://www.westsidewholesale.com/24-hour-programmable-electronic-timer.html
Tork EW100B $177
http://www.1000bulbs.com/product/8434/TORK-EW101B.html
Sylvania SA300 $72
http://www.amazon.com/Sylvania-SA300-120-Volt-Single-Pole-Industrial/dp/B000KKNEO4
8) See wiring diagrams and manuals for some of the timers listed above:
http://waterheatertimer.org/Boxtype.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
I have four of these smoke detectors in my home. They are all hooked together. Yesterday I put new batteries in all four and now they will not stop cherping. After about 8 hours I took the new batteries...
Three small chirps in one minute intervals means that the unit is needing service. The ion chamber in that unit has a fixed life span and when it expires, that is how it tells you. It is time to replace it. They usually last about 10 years.
Jul 28, 2017 | First Alert SA302 Dual System Smoke...
Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Jul 20, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has...
mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Jul 19, 2008 | Hoover Washing Machines
55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
InFocus IN72 Multimedia Projector Logo
571 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
