Question about Saeco Vienna De Luxe Espresso Machine
Grinder will not shut off - Saeco Vienna De Luxe Espresso Machine
  • 3 more comments
  • jdeboer Aug 10, 2008
    My vienna de luxe grinder will not shut off- continues grinding well beyond the normal cycle- is there a fix I can perform? thanks.
  • coromo Aug 29, 2008
    The grinder will keep going longer than normal then it stopps and the red light goes on. I have cleaned the grinder and the shoot. It will work for a while then the same things happens.
  • Anonymous Aug 31, 2008
    coffe grinder not work
  • coromo May 11, 2010
    I took the machine apart if there ist a micro switch for the grinder how does it get activated?
  • KaffeSumpen May 11, 2010
    Does it signal a error messgae after it has grinded for a while? or does it just go on and on for a couple of minutes until you have to turn it of?
I think I found a solution to my problem. The machine kept grinding longer than usual then the red light came on and no coffee. After taking the machine apart again I found the micro switch that shuts the grinder off and continues the cycle. It is located under the electromagnetic plunger that opens the coffee shoot. I checked the switch and it still worked. However one of the electric connectors was slightly corroded. After I cleaned it and put it all back together I am once again getting my coffee. :)
Posted on Oct 19, 2008
  • 515 Answers
I think there are problems with the micro switch inside the machine, if this not work properly then the grinder will go for a while and after that will it signal red.
/Mirran
Posted on Aug 16, 2008
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Is there an overheat shut off
It is very posible and a good thing to have. It is there to protect the motor windings from over heating and causing the motor to fail.
May 16, 2014 | Ryobi Grinder. 6 in. Bench Grinder BGH6110
Dewalt angle grinder comes up to speed then shuts off
without the model number I can't identify that part, but sounds like there is an electronic module if so equipped that is heat sensitive. Get back to me with the model number and I will see what I can do to help. Check for warranty repair also if that new of a tool.
Feb 01, 2012 | Saws
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
Continue to get beeping after taking out basket, emptying water, re-inserting basket and making certain lid is clicked shut. Thoughts?
All the parts have to be in place, including both the removable grinder unit and its clear cover, even if you're using pre-ground coffee.
It also requires that both the top lid and the front "door" (to the basket area) are clicked shut, and that the basket and its cover are both in place.
One thing to check carefully is the clear cover to the grinder unit. There's a rubber-like "nub" that seems to actually control the switch, which tells the machine that the grinder unit is properly installed. If that rubber-like nub is missing (and unfortunately it IS possible to remove it, particularly during cleaning) ... that could be causing your problem. If you see a hole in the top of that clear cover... you're missing that "nub".
Sep 14, 2010 | Cuisinart DGB-600 Coffee Maker
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
My dewalt dw 402 grinder, starts fine, runs for a few minutes and then shuts down. Brushes appear to be fine.
Pull it apart and clean the armature, you will find something between the brush contacts getting larger and making contact thus shorting it out, so clean the armature with fine point object do not gouge the material out of the area between the copper plates. Also blow out any metal dust you may see.
Jul 31, 2009 | Dewalt Small Angle Grinder 4 1/2"
AFTER USING FOR A WHILE THE POWER CUTS OFF.
The grinder is shutting off because of the temperature overload switch. This is normal if you are using it for a long time. Sometimes these switches go bad and need replaced as the grinder shuts off after 15 seconds or so. I don't reccomend disassembling the grinder and bypassing this, but it can be done. Hope this helps you, Rick
Apr 16, 2009 | Metabo W14 150 ErgoD Angle Grinder
try passing air in the switch they sell air compress bottle to clean the computer pass that maybe water when on grinder switch dry hope it work cheers
Jan 29, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
