Question about Ricoh Aficio GX3050 GelSprinter
Magenta/yellow ink not loading
The ink magenta/yellow will not load into the ricoh3050n. I have loaded it 3 times all with oem products it keeps saying out of those color ink. any solution...just a note could this be from the ink tubes contaminated do they have to be replaced.Thank you Ed
  • OfficeServiceAjnc
    OfficeServiceAjnc May 11, 2010
    do not touch the chip which is on the ink cartridge when you touch it the chip can electrify and get damaged
  • 161 Answers
Try replacing with a new cartridge (sealed)
Posted on May 13, 2009
2 Suggested Answers
  • 12 Answers
Clean everything w/ slightly alcohol dampened q-tips. Run Cleaning program on printer. Align cartridges.
Posted on Oct 01, 2009
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Why does my photos art C6230 all-in-one keep saying I need to replace the black ink when the back shows 100%? The printer says it is using colors to make black print
If the machine is just using magenta, yellow and cyan to make black then you get brown, not black, (that why you have a black image unit, because YMC will not make black, color system issue. unless the machine is using yellow,magenta, cyan, then black. Are you using 3rd party toner or OEM cartridges? Did you replace the cartridge before it was required?
May 23, 2015 | Office Equipment & Supplies
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
My xerox phaser 8560 MFP is showing system error 09,037.45:54135 and I can't figure out how to fix the problem.
Ink count flag stuck after melting 2.5 Yellow Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Step 1.Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
This must be performed following an ink loader replacement.
Step 2.Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt [1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
No)Replace the Ink Loader
Aug 03, 2011 | Office Equipment & Supplies
The magenta won't work. i put a new cartridge, cleaned headers, test printed. all the other colors work find but, NO magenta comes out.
This sounds like you are using an aftermarket or refilled ink cartridge. If this is the case, try putting in a new OEM magenta ink cartridge and running the deep cleaning utility 3 times. This usually clears a clogged nozzle caused by non-OEM loaded inks.
Let me know if this clears the problem. Thanks.
Sep 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Error code 09,036.44:34979 What does this mean and what can I do to resolve it?
Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Oct 23, 2009 | Xerox Phaser 8500/DN Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Ricoh Aficio GX3050 GelSprinter Logo
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
