Question about Olevia LT23HVX 23 in. LCD Television
Olevia - hidden mini HD service input
Hi, I am having a problem with my Olevia 242-S11 42" inch TV and I need some help. I have read the well documented page concerning my power issue (power will not turn on, but the blue standby light is lit) and I am wondering where the mini usb is hidden. I want to try the mini USB to USB on my computer solution to see if I can power it up that way but I am stuck since I cannot find the elusive mini usb.
Also someone wrote:
"CS20=220@25VOLTS
CS28=220@25VOLTS
CS22=1000@16VOLTS ALL ARE ON POWER SUPPLY BOARD
ALL ARE RATED 105 DEGREES DOGSET"
on the forum and I assume these are the source of the problem but I would like some more assistance on what needs to be done, any ideas?
  • sacabeans Sep 23, 2008
    Thanks. I was able to cover it under warranty and I assume they just did the same fix.
    If anyone is interested you need to return your TV in Toronto to a place at Warden/14th so you may find it easier, and cheaper just to drive it there. You still need to pack it in a box.
I have pictures of the USB port, as well as the procedure of what I did, once the USB trick quit working here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/
Posted on Sep 14, 2008
What is reset procedure for Olevia 242-t11
You have to enter its service mode option, and select the Factory Reset option there.
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Olevia 42" 242-t11 1080i widescreen hdtv...
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Mar 06, 2010 | Televison & Video
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
May 16, 2008 | Olevia LT32HVM 32 in. LCD Television
QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Dec 31, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
880 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
