Question about Xerox Phaser 8550DP Printer
Xerox Phaser 8550dt printer
Does your company take a PO for this part. This printer belongs to a school district and this is how we purchase parts. If not, we do have a credit card we can use. Thanks
  • 81 Answers
We take visa and mastercard. Call me at 5742431176
Posted on Jul 23, 2008
XEROX PHASER 3500 ERROR CODE TSK-ROOT 1087
most possible cause is the Memory added above the 32MB base is failing. if thats how you have it setup.
Remove the additional memory module from the machine and test the machine. If the machine powers up and prints correctly this confirms the additional memory has failed. Insure the memory removed form the machine is the correct memory for this product and that it was installed correctly. Replace the defective memory if it is Xerox memory. If the memory was purchased by the customer and is not Xerox memory they will need to file a warranty claim with the company they purchased the memory from.
Dec 23, 2009 | Xerox Phaser 3500/DN Laser Printer
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Mar 26, 2009 | Xerox Phaser 8550DT Thermal Printer
I have an error which popped up on my xerox 8550 Phaser. 09,035.43:117277. Xerox is offering absolutely no support and I cannot find anything on the internet of any assistance.
That is an ink loader fault. The ,43 means your cyan,( blue ) ink stick has not slid down into the ink loader properly.
Look in where you load the ink, you will find that one of the sticks is cracked, twisted or just isn't advancind down properly.
If you eed to remove them, take a screw, a drywall type screw is the best, twist the screw into the ink stick and slide it back and out.
But that is your problem, simply a stuck ink stick.
If you have an ink stick in the machine from another phaser printer model, they are all shaped differtently and may not hit the switch in the ink loader.
Dec 18, 2008 | Xerox Phaser 8550DT Thermal Printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
The display panel needs to be replaced. The part number is 802K93650. We sell them for $160 plus shipping. Our number is 574-243-1176 if we can help.
Jul 23, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8550DT
this is usually caused by a fuser but could be static from the paper depending on the fuzziness. if the letters have like a halo effect around them then it could very well be static and you may want to try a fresh **** of paper. otherwise, it probably the fuser...
May 08, 2008 | Xerox Phaser 8500/DN Printer
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 8550DP Printer Logo
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
