Question about Xerox WorkCentre M20i All-In-One Laser Printer
M20i paper jam 2
Hi - We have taken the machine apart over and over looking for any bits of paper that could be left in the machine and none are visible?? We turned it off and unplugged it. Is there some way the error message is locked in the machine without their actually being a jam??
    President:
  • 2,072 Answers
I suspect what has happened, is on the fuser, there is an asseembly across the top that has the flag assembly on it.
Most likely the tab that keeps it in place is broken and when you are putting the fuser back in, it is not actuating the sensor. That is why it keeps telling you there is a jam.
It is a black strip that runs across the fuser on a stainless steel shaft.Looking with the fuser installed and the right door opened, it would be on the upper right side. Or above the fuser toward the back.
Posted on Jul 23, 2008
  • Rick Kasper Jul 23, 2008
    There is a way to clear the memory, I don't think that will clear your jam but try this.
    Unplug your machine, and slide it out to access the back.
    There will be a little access door on back about 6 inches by 6 inches. It just has two plastic clips holding it in place. Remove the cover and remove the memory chips from their slots. With the DIMM and Sdram removed, power the machine up and let it come to ready.
    Then power down the machine again, return the memory to the slots and secure them . Then power the machine back on.
    If there was any corruption in the machine that will correct it.
    Have you taken the drum and toner out and flipped the machine on its back and slid a piece of heavy stock through the paper feeder from where it feeds out of the tray? Have you looked in the duplex area? the slot on the right side door behind the transfer roller?
    Jam 2 is normally in the fuser.
    You have cleaned the paper sensor above the fuser? It is not out of place? And the flag that is in the exit area, where the paper exits the machine, is in place?
    I have never seen that code stuck in memory. But that procedure of removing the memory . powering on coming to ready and then replacing the memory is a service way to reset odd faults.
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
I need a schematic for a Katsuda JMC4s Paper Cutter from Japan?
Hi
I had JMC III KATSUDA (SH290HOP-N) paper cutter and memory shown ERROR 2. Memory did not work. Please let me know if you have any idea to fix it. My email is
leonardprint@gmail.com
Thank you
Dec 29, 2014 | Office Equipment & Supplies
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
2x^3-3x (a) state whether the polynomial is a monomial,binomial, trinomial, or none of these. (b) state whether it is in descending or ascending order. provide a reasons for your answer
a) It is a 3rd degree binomial because there are only 2 terms.
b) It is in descending order because the degree of each term goes down as you read the expression from left to right
May 23, 2014 | Office Equipment & Supplies
Ir4570 email
Sorry, wxygzgc, but there is no indication at all in the Users' Manual that the IR4570 has any email capability.
http://www.agercopy.ro/poze/24547_1_Manual%20Utilizare%20IR%202270_2870_3570_4570.pdf
May 20, 2014 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
Xerox WorkCentre M20i All-In-One Laser Printer Logo
1,841 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
