Question about GE Refrigerators
Ice dispencer frosts up - GE Refrigerators
  • 958 Answers
The flap that covers the dispenser is not shuuting off completely that is why moisture from the outside buildsup frost on the lip of the rubber cover. please check the flapper that it seals tight after dispensing the ice.
i hope i was able to solve ur problem..
pls rate me.
tnx 4 using fixya...
drcool
Posted on Jul 23, 2008
Frigidaire Gallery series ice dispencer does not dispence ice. Also, what is proper freezer setting?
Thank you for your inquiry, friend!
Based off what you have described you are having trouble with your ice dispenser not dispensing inside of your Frigidaire refrigerator and you would like to know the proper temperature setting. You may want to open the door of your freezer and check your chute to assure that there are no ice chunks or frost causing issues with your ice dispensing. When you push on the paddle do you hear a noise? If you do not hear a noise your auger could be bas inside of your icemaker. If you hear a noise and no pushing it could be a possible problem with the motor. It is recommended to have your freezer on a zero degrees for a factory setting. I hope this information is helpful. If you need any further assistance please feel free to reconnect. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
Bottom of ice dispencer freezes and wont let ice come out. It is a whirlpool side by side
Check the door flap on the freezer door , which opens to let the ice come thru . If this flap does not close completely , then it will let frost accumulate inside the ice bin , blocking ice from dispensing . If you had given the model number , I would give the part number for the door kit .
Aug 15, 2010 | Refrigerators
How do I fix freezer so it doesn't have so much
check that the dispenser door is shutting properly and seal is OK also check if ice is not jamming door open also check that freezer is not to cold
Nov 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool side/side ice dispencer not working
I had the same problem, however, the ONLY fix was to call the repair guy and get a new part. I took it out, defrosted the unit thinking ice was in the gear mechanism, lubricated and re-installed it to no avail. The repair guy had SEVERAL of these geared mechanisms in his truck so that told me THIS HAPPENS A LOT. Good luck.
Aug 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
