Question about RCA HD52W56 52" Rear Projection HDTV
HD52W56 RCA Powers up with Sound But has No Picture High pitch squeal
Green power light comes on tv sound comes on but there is no picture. Can anyone help tv is 4years old. Mod# HD52W56, Chas# ATC321, Man.Date November 2004.
  • yldstrk Aug 03, 2008
    where is the reset located?
  • Anonymous Aug 22, 2008
    IT MOST LIKELY IS YOUR POWER SUPPLY, I HAD ONE THAT DID THE SAME THING AND IT WAS THE POWER SUPPLY WHICH COST ABOUT 100 DOLLARS FOR THE PART AND ABOUT 250 DOLLARS FOR LABOR.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Try reset.
Posted on Aug 03, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
My tv makes 3 even high pitched squeals when i turn it on. about 1 second each, then powers off. No picture no sound. All imputs. What do you have for suggestions on what it could be.
One of most two common reason why your set will not come on, is because it has lost the high voltage, the first thing to check is your horizontal output transistor, to see if it is shorted, it will be located bay the flyback, mounted on a metal heat sink. That is what is causing a squealing noise.
Oct 16, 2010 | RCA HD52W56 52" Rear Projection HDTV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
No picture no sound
First check to see if you have any voltage at test points with a digital meter.
You may need a repair manual for this.
Since you hear some noise your main fuse is ok.
Try checking this tp voltages first.
BE CAREFUL, wear gloves
Feb 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
197 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
