Question about Samsung Refrigerators
Stop to work and when switch off and on again working for other while.one time a month need to stop to take out the ice from frizer from bottom.THE WALLS ARE HOT IS WELL.model no frost-RL33SB.THANK YOU
  • 958 Answers
I think you are having a defrost problem or ice build up on the freezer.
three things,
timer that controls the defrost schedule.,
bi metal in series with the heater ,
and the heating element itself.
i hope i was able to solve ur problem..
pls rate me.
tnx 4 using fixya..
drcool
Posted on Jul 23, 2008
I have 10 years old Profile, side by side refrigerator, model TPX24. Today there was water on the floor, ice was melting, and the top part of refrigerator was wormer then the bottom. I defrosted it. water...
If you can hear the compressor come on, then I would suspect that it needs either freon or a "cold control switch". Usually it is not the switch. If the compressor tries to start but just makes a brief buzzing noise and then shuts off, then the compressor may be bad.
Jun 24, 2010 | Refrigerators
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Ice maker stopped working after about 6 months
Sounds like the ice maker heater (which releases the cubes) is not working. Individual parts are not available. The entire ice maker must be replaced, but since you say it is only 6 months old, it would be covered under the factory warranty. Find a service provider (in the US) at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
May 19, 2009 | LG LFC25760TT Titanium Bottom Freezer...
Ice at the buttom of the frizer
There is excess ice build up due to a clogged drain in the freezer. You need to defrost your refrigerator for about 3 hours by unplugging it. If thats not an option empty the freezer locate the drain after removing ice and blow dry the drain hole. Also for your info the water in the fridge is the drain off thats supposed to be drained when the refrigerator defrosts every 4 hours or so. Also the excess ice is caused by the same thing.
Let me know if you need further assistance
Sincerely,
Michael Scott
May 07, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Akai frizer
on the top of the motor there is a plastic cover which contains a thermal button,try to hit it in this spot and if it works you might change it with another
Nov 18, 2007 | Freezers
Samsung RB215LABP Bottom Freezer Ice Maker..
refrigerator working great then the refrigerator portion went frmo 35deg to 61 freezer is at 4deg can not understand whats up and i cant get the damn thing to do ****
Oct 07, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
