Question about Kenmore 63942 Dryer
I have the Kenmore 64201 74201
The dryer still buzzes when you change setting and clicks when off. But still won't run. Please advise:)
  • Jenniferv2 Jul 23, 2008
    Oaky, when the dryer is turned on, the faintest sound of the motor in the timer can be heard. Otherwise there is no sound. Sorry:(
  • 3,422 Answers
See if you hear a click sound then it is a bad thermal fuse.Please replace it and please don't forget to accept my solution as fixya in the premium problem which you rate before.
Posted on Jul 23, 2008
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Kenmore dryer model 110.66722692 won't start
does the drum travel up and down losely. if so the spindle at the rear of the drum in the centre has worn and needs replacing
Dec 21, 2011 | Kenmore Dryers
I put too many wet items in dryer. I think.. it stopped and won't turn on.. it would buzz when trying to start it, but now won't do that.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 23, 2011 | Kenmore Dryers
My kenmore gas dryer model 110-76662501 is making a thumping noise while the dryer is running. The dryer is about 5 years old used about 3 times a week. The clothes dry fine. Maybe a pulley or...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 11, 2011 | Kenmore Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Combo Kenmore dryer buzzes when turned on. Dryer
Your dryer motor is being told to turn, but cannot. One possible reason is due to lint build up on the motor shaft.
Here is how it works: the motor has a set of starter coils, and a set of running coils. There is a momentum actuated sliding switch on the shaft. When the motor starts from the normal rest position, the spring loaded switch on the motor shaft makes contact with the set of starting windings on the A/C motor. When the motor reaches a certain speed, the momentum of the motor causes weights on the collar to try to move outward. Through this outward movement, the force is directed through a mechanism which moves the collar on the shaft to the other set of contacts for the running coils of the motor.
In some cases, lint builds up on the motor shaft and can cause the sliding switch to lock into place instead of being able to slide back and forth. If the collar is locked into place over the running contacts, you could get this buzzing noise. The motor is trying to run, but doesn't have enough torque to start, and therefore will sit and buzz....
Jun 24, 2009 | Kenmore Dryers
Kenmore Dryer 60982 Runs but No Heat
you can check them all with an ohms meter but i think it is the thermal fuse at the top of the heater box that is bad-mike
Jun 04, 2009 | Kenmore Dryers
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore 63942 Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
