Document Feed Please help, my Panasonic FP-D350 copier is having problems. The document feeder will not "feed" the papers through for printing; everything has to be laid on the glass. Any suggestions?????
  • 1,326 Answers
Is the adf showing a paper jam at all? If so try to look for a small piece of paper & staple & paper clip & or a post-it note, blocking the paper path.. If the copies get pulled in and stop.. look right in front of where the copies stoped,that is where your problem is...
Posted on Jul 25, 2008
First u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Posted on Jul 24, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Help-the paper feeder does feed the paper so the amounts print on top of each other.
If the document feeder is not feeding paper properly, the first thing I would suspect is the feed rollers ( 2 or 3 in total,) as they have the tendency to become dirty and worn. My suggestion would be to open the document feeder, take a clean rag and some general cleaner (no solvent,) and wipe down each roller as best you can. This will act to remove any trapped dirt or debris in the feed roller traction marks, and thus give you a more reliable document feeder. However, if this fails to alleviate the issue and the rollers appear worn, replacing them would be your next step.
I would suggest precisionroller.com as a good source for printer, copier, and fax supplies.
-David.
Nov 05, 2010 | Office Equipment & Supplies
Where is the auto feed for the copier. i have about 15 pages to copy and i do not know how to use the auto feed. thank you for your help
The question is that if the copier is equipped with an automatic document feeder or not. If you'll see on the top of your copier only a piece of plastic, most likely your copier don't have the feeder but if you see something far more complex, just put your paper there and press the Start button
Sep 03, 2009 | Panasonic FP-7735 Black and White Copier
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
116 people viewed this question
jasbo
jasbo
