Philips 42PF3320/10 plasma tv screen goes blank but power remains on
Hi.
I have a problem with my 42 inch plasma tv,when tv is turned on green L.E.D appears on bottom right and tv works as normal.After 40 minutes to an hour tv makes click sound and screen goes blank the green L.E.D changes to red on the bottom right there is still power going to the tv hence the red L.E.D.Then when i plug it out and plug it back in red L.E.D appears but screen remains off it stays like this for 3 to 4 hours before tv comes back on and the same is repeated again after 40 minutes or so.
Confused and in need of help: Brian in Ireland
  • redmullen Sep 07, 2008
    have same tv in ireland.. tv wont turn on after repeated attempts. green light flashes for few secs and then red light. need help - Linda in ireland
2 Suggested Answers
  • 1156 Answers
SOURCE: Hi. I have a problem with
Hello, A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage.
I hope that this help to rectify the fault of the projection TV....
Posted on May 12, 2011
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Philips Televison & Video
Hi. I have a problem with my 42 inch plasma tv,when tv is turned on green L.E.D appears on bottom right and tv works as normal.After 40 minutes to an hour tv makes click sound and screen goes blank the...
May 12, 2011 | Televison & Video
2006 42" plasma has blank
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Televison & Video Logo
771 people viewed this question
Top Televison & Video Experts
