Check printer message reoccuring. Have tried opening cover, turning off machine etc...model H12297 (color image class MF8170c)
  • 36 Answers
Check to make sure everything is in place on the interior of the printer (such as your ink cartridges).
Posted on Jul 23, 2008
I am having a problem with one of my Printers, it is a brand new printer, Model Canon Image CLASS MF 3222. It was running alright for about 2 weeks, now it displays on Printer LCD ( System Error 225 ).
If you open the scanner cover you should find that the scanner lamp is not lighting. as the machine is 2 weeks old it will be covered by the warranty. Telephone canon service to book at service call and it should be repaired free of charge.
May 23, 2011 | Office Equipment & Supplies
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
I am getting a System Error E021, what does this mean?
In my home office this error message came up, E021. I opened the Printer cover, closed it, unplugged and replugged and got a Paper Jam message. I removed the paper jam and did the cover/plug routine. Now I have a message CHECK PRINTER OPEN AND CLOSE COVER. But I can't find anything wrong! I have been searcing for an explanation of the error message online, but haven't found that either. my printer may be infested by aliens.
The best advice I can give is to reseat the various parts (drum and toners).
Aug 17, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Canon FB630u problem
I have struggled with this same issue for ages, I just found a fix from the HP site for the same problem with an HP scanner - it worked for my Canon LiDE70. Run regedit then:
  1. Double-click HKEY_LOCAL_MACHINE to open the folder in the left pane of the window.
  2. Double-click SYSTEM , CurrentControlSet , Control and then Class .
  3. Select {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and check in the pane on the right for the Lower Filters string value.
  4. Right-click Lower Filters and delete it.
  5. Disconnect the scanning device and restart the computer.
  6. Reconnect the scanning device after the computer is restarted.
  7. BINGO! it worked!
Feb 13, 2008 | Canon CanoScan FB630U Flatbed Scanner
Color imageclass mf8170c
You Cyan cartridge is getting low. Buy one now because there is no warning to when it decides to up and quit and you wont be able to print anything!!!!
Jan 23, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageclass MF8170c print problem
i have Image class MF 8170 c Just printing blank erro code
apear on display.
Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
MF-8170C REC. PAPER JAM and Open Cover
Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
System Error E197
I get that error sometimes, i called Canon they don't know any solution for that error code, i always fix it by turning off the machine and turn it back on, and it work just fine, but i keep getting it once every two week, its something has to do with the Voltage on the machine, it may not get enough power, or is getting more power.
Sep 19, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
56 people viewed this question
