Question about Sony PlayStation Portable (PSP) Console
The screen on my psp has started flashing on and off. It does this until it completely cuts off. Then i have to leave it off for long periods of time for it to be able to come back on. Im not sure why it does this?
I had the same problem before.Try charging the PSP for four hours and then play.
Posted on Jul 23, 2008
I have kingston datatraveller 100 G2 4gb its internal software had been gone since it had fell into water so plzz tell me link to download software
if it has fallen into water it might have been damaged beyond repair
the only thing you could try is to dry it out
leave it in a dry place
Dry the flash drive as much as possible with a piece of paper towel to absorb excess moisture.
Gently pry open the case of the flash drive if possible, using a small flat-blade screwdriver to separate the two halves of the case.
This is not essential, but will cut the drying time and will help to limit corrosion.
Dry the inside of the case as much as possible with the paper towel.
Pour some uncooked rice into a small plastic bag, and then place the flash drive in the bag and seal.
Place the bag in a warm, dry place for at least 24-hours.
The rice draws out and absorbs any moisture present, speeding up the drying time and ensuring the drive is completely dry.
Check the drive after 24 hours.
If you can see any moisture, leave the board for 24 hours and repeat until the board is completely dry.
Reassemble the case, ensuring the two halves are tight shut. Use a small spot of glue to hold the two halves together securely if necessary.
You can then use the flash drive as normal.
hope this helps
Sep 15, 2012 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Fourth times when i off the psp and then turn on back, everything hang and not able to play at all. can anyone teach me how do reboot like the shop pple. they charge me each time and not willing to teach...
First, try holding the power switch for 10 seconds, this does a complete reset of the PSP, but doesn't reset it to factory settings.
If that doesn't work, turn it off the same way as above, but this time, hold SELECT, START, square and triangle as the machine starts up. Keep holding them down until you see the screen light come on, but just a blank black screen. It'll show that screen for a few more seconds, then it should be just like it was when you took it out of the box. You'll go through the initial setup again.
Here's the video I got the information from: http://www.youtube.com/watch?v=MCsFiWO03d0
May 10, 2011 | Sony PlayStation Portable (PSP) Console
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
My psp fat drains battery so fast
you have to get a new battery becouse the firs time you charge it you did not leave if untill it was completed(you must leave it untill it is totaly completed every singel time).HOPE I WAS USEFULL PLZZZZ RATE ME.
Jan 10, 2010 | Sony PlayStation Portable (PSP) Console
Recovery Screen Not appearing
Hold the off button until it completely shuts down then hold the right shoulder/trigger button and at the same time turn the psp on! Hope this works for you!!
Jul 04, 2009 | Sony PlayStation Portable (PSP) Console
My psp froze
i understand ya... I used to deal with psp's before.
Now i want more info.
What model is it? and when you turn it on now what happens?...
This might require you to re-flash your psp.
and by how it sounds to me it seems like you dont really have much experience with psp's
Try searching on google for "Unbrick PSP" you will find more info.
Another way is to go on craigslist.org and search around your location for "psp" reapair ppl. Usually this should not cost more then 20 bucks.
Apr 24, 2009 | Sony Video Game Consoles & Games
Psp game doesn't work...
The game that you got from the promo when you bought your psp has expired. They gave you a certain amount of time to play the game before they make it expire. They do that so that you can go out and buy the actual game. They give you a free demo to convince you to buy the actual whole game so they can make more money. And your psp cuts off when you leave it sitting for a period of time to save power and to avoid killing your power. It is a setting that you can change in the menu of your psp. You can change the amount of time you would like it to stay on while sitting un-active.
Dec 27, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
