Question about Provo Craft Cricut Disney Font Cartridge
Hi, I am a Cuttlebug user in India. Recently the rolers in my CB have moved far apart lettig the plates pass through with no pressure. Its an year old already and i dont have anyone to help me in India. I will appreciate if you can teach me how to fix it back. I am hoping the machine has not broken as i am very careful while using it. Thanks.
  • Julie Kitchener Nov 19, 2017
    Hi I think your cuttlebug may be broken, I suggest writing to the maker and ask them for advice. Hope this helps.
  • Denise Lane Nov 22, 2017
    One gentlemen shows how he fixed his wifes,after the mfg.said to keep it and sent her a new one. http://tunnel13.com/blog/cuttlebug-v2-re...
    He refers this link for an older onehttps://www.youtube.com/watch?v=wmyGnOZG...
    Hope it helps you.
3 Suggested Answers
  • 4966 Answers
SOURCE: cuttlebug breaks apart when a cutter is put
The reason this is happening is because the metal casting (inside the green plastic casing)  on one side (where the driving cogs are) has cracked due to trying to force through something that was too thick..
Unfortunately there is nothing that can be done with it apart from complain to the manufacturer
Posted on Sep 15, 2009
SOURCE: side popped off Cuttle bug now no pressure
Mine has just done the same, have you found a solution?
Posted on May 20, 2010
Rebuilt presureplate installed from factory as delivered will not release clutch did it need to be adjusted or released?
Did you install the clutch plate correctly? If you put it in backwards, the pressure plate will not be able to move far enough to release it. If the clutch plate is in correctly, you need to check if the clutch release arm/linkage or the slave cylinder is working properly. You didn't mention a make, model or year, so these are just generic suggestions.
Apr 29, 2017 | Cars & Trucks
Is the throwout bearing stuck to the pressure plate or could it be the shredded disc causing the jamb
Hi Gregg:
Seems to ne that if you know the disc (clutch plate?) is "shredded" you will need to dis-assemble it to do the repair so it really won't matter what "coould be" since you will find that out when you have taken it apart. Bottom line is, if you have to take it apart anyway, there is no point in guessing.
Best of luck. Hope it goes well.
Cheers and
Happy New Year.
Jan 02, 2016 | Cars & Trucks
How far does pressure plate move when you pull in clutch
Hi, Cornell usually about .125" but it all depends on the year, make, and model of your motorcycle. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 19, 2015 | Motorcycles
Broken channel selector knob on cobra DX IV cb radio
Remove the outer knob, you may have to remove the front plate to get at the nut, you should now be able to tighten it up for ease of use.
May 05, 2012 | Cobra Radio Communications
Cuttlebug machine
Hi Mike, it was your name i noticed, it is not Mcmurtha by chance is it, if it is we are related
Nov 14, 2011 | Crafts & Hobbies
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
1995 intruder 1400 clutch
That is more than enough movement. Most probably don't move half that much. All they have to do is release the spring pressure from between the plates.
Sep 20, 2009 | 1995 Suzuki VS 1400 Intruder
Provo Craft Cricut Disney Font Cartridge Logo
1,584 people viewed this question
Top Provo Craft Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
