Question about Graco LeisureSport 7420 Jogger
I have a graco 3 in 1 travel system with a car adapter base. When fitted to the back seat of our 1999 renault scenic due to the angle of the base of the back seat the car seat is too upright causing my daughters head to fall forewards (she is only 2 weeks old). The adjustment leg of the base jacks the seat up at the back but i need it ot be jacked up at the front because at its lowest setting it is still too high. Are there any spacers or adapters i can purchase to adjust this as a new car is out of the question. The front seat has an airbag which cannot be turned off.
Found copy of manual at www.gracobaby.com. Page 39 explains that the rear of the car seat base can be levelled up using a rolled up towel.(http://www.gracobaby.com/assets/pdfs/instructions/851-6-02_ISPC021BB.pdf)
Posted on Jul 25, 2008
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
Jul 26, 2012 | Graco Baby Gear
Does the Graco car seat base (for Graco Junior) fit into Daewoo Lanos 2004 back seats?
Best bet is to buy it and take it to your local fire department or highway patrol. Here in California the CHP, California Highway Patrol will attempt the install for free, they are trained to do so. If the officer says no then the reality is that you may want a new car. Graco seats are great and the size of seats are similar across brands. Good Luck
Jan 23, 2012 | Baby Gear
I washed my daughters graco car seat and now i havent a clue of how to put it back together and i need re assemble it fast please help
Proper installation of a car seat is imperative to protectan infant. Accidents do happen and assuring that the instructions forinstallation of the Graco Infant Restraint/Carrier are followed will increasethe chances of preventing injury or death as a result of an accident. Graco carseats are a popular choice among parents due the availability of products atcommon retail stores, affordability and user-friendly baby gear.Graco Car SeatInstallation
Step 1
Plan to secure the infant seat facing the rear inthe middle of the back seat. If a center position is not available, positionthe seat directly behind the driver's side seat. For safety reasons, therestraint should not be placed in a position where there is an air bag. Ensurethat the proper vehicle lap belt system is in place; manually adjusted lapbelts, automatic locking retractor lap belts and lap/shoulder belts withlocking latch plates are all considered safe for use with the Graco InfantCarrier/Restraint.Step 2
Remove the carrier from the Graco car seat baseby squeezing the lever at the rear of the restraint and lifting the seat up.Place the base in the vehicle facing the rear. Thread the vehicle shoulder andlap belts through openings at the end of the base without twisting the belts.Secure the belts by placing plastic tongue over the belts. Tighten the vehiclebelts by pushing down on the base and pulling out any slack.Step 3Install locking clip to secure shoulder and lapbelt together just above the seat belt buckle. Connect the two belts with thelocking clip. Buckle the lap belt system and tighten by pulling out any slack.Ensure that car seat base is secure by pulling and pushing on it; the baseshould not move sideways, forward or backward.Step 4
Place the Graco carrier in the base. Push down onthe restraint until it clicks and locks into the base. Set the infant in therestraint for travel and place harness straps over the baby's shoulders. Clickthe chest place together over the sternum and lock the buckles into placebetween the legs.Tipsand Warnings
  • Contact local police departments, hospitals and fire departments to inquire about child car seat safety checks
  • Graco Infant Restraint/Carrier will not protect against serious injury or death if not installed properly. Always read the Graco owner's manual that comes with product prior to attempting installation and travel with an infant.
Jul 19, 2011 | Home
How do you latch the car seat into the stroller on
Found owners manual. Latch from car seat fits into cup holder on front of stroller.
Nov 15, 2009 | Graco Quattro Tour Travel System
I just purchased a graco literider 320 stroller
Yes, you can get a matching car seat with base. try your local baby store, or look online for the travel system..once you find the travel system, you'll find the car seat.
Aug 04, 2009 | Graco LiteRider 320 Travel System 7303BRL...
Is this stroller compatible with other car seats such as Graco?
The manufacturer will not say that your Graco seat will fit in their stroller safely, however you could try your Graco in it and see if you feel safe that it will not fall out or be pulled out by your toddler.
Perego prefers to market their items to go with their car seats only, but we have found that the Graco seats fit nicely in most strollers. You should hook the stroller harness on to the lap belt routing path on your car seat to ensure safest travel in the stroller.
Good Luck! from Moms Just Know
Oct 02, 2008 | Peg Perego Tender XL- Black Sable Twin...
Graco ex duoglider in colburn
the car seat faces the mum and just slops in hun
Mar 29, 2008 | Graco DuoGlider Travel System 7444SAR -...
Graco metrolite travel system
I believe the link below is what you need to download.. http://www.gracobaby.com/assets/pdfs/instructions/447-4-02.pdf Please check the website for other important information: http://www.gracobaby.com/default.aspx
Jul 28, 2007 | Graco Stay-in-Car 8402L
Graco LeisureSport 7420 Jogger Logo
137 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
