Question about HP DeskJet 9800 InkJet Printer
C4 size envelopes
I did manage at one stage to achieve this but I have lost the settings I used, Any help would be appreciated
  • 36 Answers
Check the sizing of the envelopes and then configure it to fit your printer.
Posted on Jul 23, 2008
How do I print envelopes. I'm using Open Office 4.1.1 and Samsung printer CLX3305FW
From the main menu click on Format, Page, then choose one from among five envelope sizes available from the Paper format. Available envelop sizes are DL, C6, C6/5, C5 and C4. Click OK. You must now be able to see in the print menu the envelope size you just chose.
Nov 22, 2014 | Samsung Office Equipment & Supplies
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Printing C4 Envelopes on a CANON 2620N
try to use this linkhttp://www.canon.com.sg/section/contactus/?enqtype=TechEnq&enq_detail=Copiers
Aug 09, 2009 | Canon imageRUNNER C3200 Copier
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
I have a Lexmark C510, how do I print a business envelope?
You can load up to 10 envelopes in the standard tray. Try a sample of any envelopes you are
considering using with the printer before buying large quantities. See Loading envelopes in the
standard tray
for instructions on loading envelopes.
When printing on envelopes:
To achieve the best possible print quality, use only high-quality envelopes that are designed
for use in laser printers.
Set the Paper Source in the Paper Menu based on the source you are using, set the Paper
Type to Envelope, and select the correct envelope size from the operator panel, the printer
driver, or from MarkVision Professional.
For best performance, use envelopes made from 90 g/m2 (24 lb bond) paper. You can use up
to 105 g/m2 (28 lb bond) weight for the 250-sheet standard tray or 105 g/m2 (28 lb bond)
weight for envelopes as long as the cotton content is 25% or less. Envelopes with 100%
cotton content must not exceed 90 g/m2 (24 lb bond) weight.
Use only new, undamaged envelopes.
For best performance and to minimize jams, do not use envelopes that:
Have excessive curl or twist.
Are stuck together or damaged in any way.
Contain windows, holes, perforations, cutouts or embossing.
Use metal clasps, string ties, or metal folding bars.
Have an interlocking design
Have postage stamps attached
Have any exposed adhesive when the flap is in the sealed or closed position
Have nicked edges or bent corners
Have rough, cockle, or laid finishes
Use envelopes that can withstand temperatures of 170°C (338°F) without sealing, excessive
curling, wrinkling, or releasing hazardous emissions. If you have any doubts about the
envelopes you are considering using, check with the envelope supplier.
Adjust the width guide to fit the width of the envelopes.
Load only one size of envelope at a time in the tray. Envelopes may only be loaded in the
standard tray. Load them with the flap down and the flap to the left of the tray.
A combination of high humidity (over 60%) and the high printing temperatures may seal the
envelopes.
Loading envelopes in the standard tray
The recommended stack height is 10 envelopes; however, in normal environments as many as 15
envelopes may be loaded. In high temperature or humidity environments, only seven envelopes
should be loaded.
1 Pull the standard tray completely out.
2 Squeeze the length guide tabs together as shown in step 2 on page 42. Slide the guide to
the correct position for the size of envelope you are loading.
3 Squeeze the width guide tabs as shown in step 3 on page 42. Slide the width guide to the
correct position for the size of envelope you are loading. Notice the size indicators on the
bottom left of the tray.
4 Push the envelope stack aid tabs toward each other. They snap into place.
5 Flex a stack of envelopes back and forth and then straighten the edges on a level surface.
Press down the corners to flatten them.
Fan the envelopes. This prevents the edges of the envelopes from sticking together and helps
them feed properly.
6 Load envelopes flap side down with the stamp area and flap on the right. The end of the envelope with the stamp area enters the printer first.
7 Insert the standard tray.
Feb 26, 2009 | Lexmark C510 Laser Printer
Printing card envelopes
It sounds like you may have a size mismatch in the settings. Please refer to this link for information and the settings that you need to verify. You should be able to refer to the packaging for the envelope size to select.
Hope this helps. Please rate this information.
Thanks
Nov 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
HP DeskJet 9800 InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
