Question about LG WM-2277HW Front Load Washer
Problems with LG WM-2277HW Front Load Washer
I have a problem with this LG WM-2277HW front loading washing machine. The dispenser tray is stuck in the closed possition and I cant get it open. Is this a common problem for this model? Does anyone know of a fix?
  • sykescats Dec 28, 2008
    We too had this problem and after $200+ dollars had a service technician come out to replace. He made the "fix" look VERY difficult - I think so that we would call him again to come out and "fix." I did have to get a brand new dispensing tray, but I am once again experiencing the tray "sticking" which is how the problem started out the first time before it just stuck permanently. If this happens again, I think I'll try to "fix" on my own following the poster's comments, but I'm seriously thinking of just getting a new washer (not LG) and being rid of the issue all together. The washer is only 3 years old and between the mold smell and this it just seems like I've purchased a bunch of junk for a very high price. :(
  • 489 Answers
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Posted on Jul 24, 2008
  • Gary M Jun 17, 2012
    Once you have removed the four screws from the back that hold the end of the lid, the lid slides backwards (some convincing is required). You have to push it back w about three inchaes, before you can lift the top up. There are four nobs on the top of the wahser that are holding the top down. Once you push the top back about three inches or so You should be able to lift the top off. Once the top is of you only have to loosen the three plastic latches on the inside and push the lid to the dispenser a bit to pull the dispenser drawer out. In our case the blue Softener holder was the cause of the drawer getting stuck. Its two plactis holders in the back had worn out and were not holding the cup dow, which was getting stuck on thetop plastic. We used sowing tread to circle around the container, going above and under the compprtment where the cup rests to force the cup to sray in place. Drawer not closes without issues. You problem may be something else, like the bleach reservior, but I suspect softener reservior with smaller holder is
    more likely the source of your problem than anything else.
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
Machine will not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 17, 2011 | LG WM-2277HW Front Load Washer
Lg wh2277hw will not spin. takes water and attempts to spin but no.
heatman101
Jan 14, 2011 | LG WM-2277HW Front Load Washer
The washer can't drain the water?
heatman101
Sep 06, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
Can I use bleach with the laundry detergent for a load of whites?
Hi
Thanks for using FixYa. You need to preload all your detergents/liquids in a tray and let your washer do the work. No more “figuring out when to add softener, bleach or detergent”. The electronic controls on the LG WM-2277HW are clearly labeled and easy to use. This washing machine comes with standard dispensers for fabric softener and bleach and there is also a detergent dispenser.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | LG WM-2277HW Front Load Washer
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Lg wm-2277 dispenser tray
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Regards Faggly
Mar 19, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
623 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
