Aiptek T20 Pocket Cinema DLP Projector Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi! I am trying to find out if a T20 can be used with a mac? Is there some driver or something else that I can install to make it work?
Anonymous
Level 3:
Guru:
  • Master 767 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Guru:
Answers
767
Questions
0
Helped
188175
Points
1958
You could always give it a try on your Mac and see if it auto identifies.
You can see the system requirements for this projector here.
From the looks of it, it seems the projector is only compatible with Windows XP and Vista.
3helpful
2answers
I have a new MacBook Pro and cannot get my Brother printer to work with it. The computer recognizes the printer but does not print.
Did you install the Mac driver for MFC? The MFC comes with driver for windows and Mac. Place the Mac Driver disk to DVD slot and run the installation for your MFC printer. Follow the instruction to complete the installation.
When you try to print something, make sure the MFC printer is selected.
If you've done all of this and still not able to print, please turn off your MFC, wait 15 seconds and turn on again to see problem solve or not.
Hope this will help. Thanks for reading.
1helpful
Does any driver or software exist to use the RR-US430 Panasonic recorder directly with Macintosh through the usb cable?
It appears that the RR-US430 only has driver software that is designed to work under Windows Vista. There is no specific Mac software available on the Mac, are there any claims that the device will work directly connected to a Mac.
If you have an Intel Mac, and use Bootcamp, Parallels or VMWare Fusion, you could try installing Vista using one of those methods, then running the driver software from here to see if your RR-US-430 is recognized while running Vista on your Mac.
It's a longshot, but pretty much the only option you have if you really want to try using the recorder on a Mac.
Good Luck!
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
1helpful
Ethernet drivers
My thinkpad R50 also has same problem, I update the driver and patch from the lenovo . You can update your network card diver and then open the admin tools to add the ethernet controller. Take a try.
Good luck.
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
IBM ThinkPad T20
Wow, a lot of information but I'm unclear as to what you are trying to do.
Are you connecting the T20 directly to the T40 using a cat5 cable and then trying to access the internet on the T20 via the modem?
Connecting the two computer together using a normal cat5 will not work, you need to use a crossover cable otherwise you are connecting the send to the send and the receive to the receive.
You can also use a hub, a switch or a router if you have any of those on hand.
As for the modem, I suggest you unplug the telephone line from the modem and plug it into a phone and see if you can hear a dial tone. If you cannot hear a tone either the extension is bad (replace) or you outlet is defective. If you can hear a tone, the modem card may be defective.
2answers
Not using full display on IBM T20
That would be my guess. Go to the laptop manufacturer website to get an updated one.
Compaq T20 printing
dear you will have to make a print server then you can share you printer,install the printer driver then access from client computer then you can use both printers
Top Aiptek Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Aiptek Office Equipment and Supply Expert? Answer questions, earn points and help others
