Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8550dt printer
There is nothing showing on the display panel. It first started by displaying inverted letters, then garble, and now blank. The print out sheets states hardware failure - Front panel - data path failure (16.4) Do you know what part I should replace for this?
  • Anonymous Oct 24, 2008
    I have exaclty the same problem as decribed above.
  • 81 Answers
The display panel needs to be replaced. The part number is 802K93650. We sell them for $160 plus shipping. Our number is 574-243-1176 if we can help.
Posted on Jul 23, 2008
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
This is a common problem for this printer. You need to replace the control panel. It's easy and requires no tools to do so. Hope this video helps ">
Posted on Jan 29, 2011
  • 36 Answers
You need to consult an Xerox technical support person. Since the parts are only available through them.
Printer all of a sudden stopped printing, (LED screen out so unable to read errors). Everything was working fine and then it just stopped printing any more jobs, the red light was on the control panel and...
The inverted, blank, or garbled display is pretty common, a new control panel will fix that and is super easy to install and no tools required. Here is a video that shows how.">
Jul 04, 2010 | Xerox Phaser 8550DP Printer
Can't read the display window on Xerox Phaser 8560
I have seen the same behavior on my 8560N. Sometimes the screen will be backlit, but the characters on the display are garbled. Other times, the backlight is off and the screen is blank. No manner of button pushing or tweaking the printer web server will bring the display back on. After a while, the display will just clear itself. I did not see this behavior until after I had a REALLY bad paper jam and some cardstock became lodged inside the print engine. I had to take the printer body panels off (which required disassembling the display interface. When I put it back together, everything worked, but the display started this strange behavior the next morning. Is it related? I don't know, but it sure was coincidental timing if not related.
May 18, 2010 | Xerox Phaser 8560MFP Laser Printer
The text on the printer's display shows up backwards, upside down, and when you scroll thru it, things get all cluttered. The printer operates just fine, its just impossible to scroll thru the menus on...
If your 6360 has a blank display, garbled characters, inverted, upside down, or backwards display the control panel is bad and must be replaced.
Here's a video to replace it. It's very easy and takes about a minute.
Apr 30, 2010 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox 8550 hardware failure front panel data path failure 16.4
It sounds like the display panel has gone bad. Possibly the text is garbled or only half shows up??
If you contact Xerox and tell them, I believe they will send you a replacement display panel - even if your printer is no longer under warranty -- IF your printer has never been sent a replacement display.
I've had this happen on several of these printers - I believe they know there is an issue with the display panels, which is why they are sending replacements for free.
I find the easiest way to contact them is to go through the support section at xerox.com and search for that error, then hit contact us at the bottom of the page. It'll ask for your contact information as well as the serial number of your machine.
Jun 09, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8550DT
this is usually caused by a fuser but could be static from the paper depending on the fuzziness. if the letters have like a halo effect around them then it could very well be static and you may want to try a fresh **** of paper. otherwise, it probably the fuser...
May 08, 2008 | Xerox Phaser 8500/DN Printer
Display on Xerox Phaser 6350 not working unable to network printer
Defective Control Panel. In early 2006 a defect was found with some of the Phaser Control Panels. This has been corrected in manufacturing and new versions of the control panel placed into inventory. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Try the Engine Only test print on the rear of the machine. If the print is successful, the display is defective and needs to be replaced. Using the Centerware IS (CWIS) and using the Support Tab will connect you to Knowledgebase for any procedures on how to change this control panel. Contact Product Support, 800-835-6100 for any other questions regarding this issue.
May 01, 2008 | Office Equipment & Supplies
The front panel shows nothing
When our control panel went blank last month, Xerox did not offer a free replacement because our printer was out of warranty. Consequently, we ordered one from SparePartsWarehouse.com at the best price we could find - $104.87 plus shipping. The part number for our 8550dp is 848K06551, but these are the compatible part numbers for the "Xerox 8500 Control Panel & Bezel": Compatible Part Numbers: 848K06551, 101E28730, 101E28731, 802K93650, 802K93651, 848K06550, 848K06552. It is easy to replace, instructions are on the Xerox website at http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enus.html
Hope this info helps someone, and thank you FixYa for this forum.
Aug 30, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
452 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
