Question about Kenmore 63942 Dryer
Dryer I have an old Kenmore dryer 6420 74201 and it has stopped running. No lint build up, no fuse issues, no sound at all when the dryer is turned on. Not even a click or any noise at all. Please advise:)
  • Jenniferv2 Jul 23, 2008
    The dryer still buzzes when changing settings and clicks but won't run
    What does that mean?
    Master:
  • 382 Answers
May be the machine need to be replaced as it has been affected due to over flow of current..Please try to take the device to any service centre nearby for Servicing it..It just needs a perfect service in order to bring it back to good condition..Thats all..Hope this helps you!..Thank you..
Regards!!...
Posted on Jul 23, 2008
  • 2,326 Answers
This failure could be related to a defective or seize electric motor.
This project might not be a DIY but i would suggest to read the info in this link and see if you can do it, if not I would suggest to have a tech do the work.
    Guru:
  • 1,894 Answers
Please do a hard reset and try the unit to start
  • dewan nafees ahmed Jul 26, 2008
    Plug
    something else into the same outlet. If it works, you know you have
    power to the dryer. If it doesn' t work, you'll need to check for any
    blown fuses or tripped circuit breakers. Electric dryers should have
    the wiring checked at the terminal block to make sure that the
    connection is good, or to verify that the connection is burnt out.
    If the power is there, you will want to check the door switch,
    thermal fuse, thermostats, and start switch to see if one of these is
    faulty. Make sure that the control settings are appropriate, and that
    any buttons are fully depressed. Make sure that the start button has
    been fully pushed down or turned far enough to activate the dryer.
    The door or lid switch performs two main functions. When the
    dryer
    door is open, it keeps the dryer from starting, and turns on the light.
    If the door switch is faulty, your dryer won't work, and you'll need to
    replace the switch. The door switch is located inside of your dryer's
    main housing right by the door frame. You'll probably need to access
    this switch through the top or front of your dryer.
    There may also be a problem with the start switch. Test and
    replace if it is faulty.
    Many dryers use what's called a thermal fuse. This is often
    mounted
    within the exhaust duct in the back panel. This fuse is about an inch
    long, and is usually found within a white plastic housing. Your dryer
    will not operate if this fuse is defective. You can test this fuse, and
    if faulty, replace it.
    Most fuses have a thin wire that conducts electricity. When
    fuses
    blow, it means the wire is broken, they have no continuity and no power
    will flow through it. When this happens to the thermal fuse, your dryer
    either doesn't work at all, or it stops heating. Give your vent and
    heating system a visual check before you replace this fuse.
    You will also want to test each thermostat to determine if any
    one
    is faulty. A bad thermostat may prevent your dryer from working at all.
    hard reset means leaving the unit turned off by plugging out from wall power for one night. and then turn on the unit.
    Genius:
  • 3,422 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
My kenmore 800 series dryer gets way to hot, why is that? how do I test the thermostat/ thermister?
You may have lint build up somewhere I side the dryer. You may need to open up the dryer and clean out the old lint.
Nov 07, 2012 | Dryers
I have a Kenmore dryer with Model # 110.C67711600 and Sr. # MU2206156. It is 2 years old and all of a sudden, dryer stopped drying. Clothes remain damp and wet even after running the dryer for 60-70...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Jan 02, 2011 | Kenmore 62622 Electric Dryer
All of a sudden the dryer will not turn on and it is only 3 years old.
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Oct 27, 2009 | Dryers
My fridigidaire dryer that is similar to the affinity but 3 years old has stoped working. i have a load of clothes in, it stops and all of the lights are flashing
Oct 15, 2009 | Frigidaire Electric Dryer
My Dryer just died. Just stopped working and won't turn on
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 21, 2009 | Dryers
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore dryer 110.875626011 will run but no heat. I checked for line voltage and continuity across the limits and the element which checks out. I also check the sensors on the exhaust tube. one has...
Its really a whirlpool. It sounds as if your thermal fuse has blown. If you look up your model on sears.com you can look at the break down to locate the fuse. These parts usually go because of overheating, caused by vent issues. Restrictions, blockages or too long of runs are usuall the problem. Once fixed, try running it with the vent off for a few loads. Identify if there is build up of lint in the lint catch area and base of unit. These signs of build up usually indicate a vent issue.
Apr 01, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore Dryer stopped running
This sounds like you may have blown the thermal fuse.  If you turn the dryer around facing the back, remove the screws holding the back panel on (be sure to unplug the pigtail from the wall!!!).  When you remove the back panel, down towards the bottom, you will see a plastic piece (could be long and square, or rounded type.  Do believe it will be the long type) with 2 wires going to it.  It has a screw that holds it it.  This fuse protecs the unit and motor from excess heat and electrical issues.
THERMAL FUSE
Part Number: 3392519
Oct 12, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
