My Samsung HCM 4215 42" rear projection tv is having a problem with the color. Any red in the picture drops down like a wave. Not sure if this can be fixed on my own or not.
  • 2 more comments
  • xbcolex24 Jul 23, 2008
    Any words displayed on the screen have a red shadow below it. Sometimes the red shadow drops towards the bottom right corner. The picture is also blurry.
    How do I fix the problem
    it says Nov. 2002 on the inside
  • xbcolex24 Jul 28, 2008
    any step by steps on how to fix this
    Genius:
  • 1,689 Answers
This could be a plossible issue with your CRT socket
Here is a post i made on one of the tint/color shadow issues previously:
as per description you have an issue with the CRT socket that solder on the part may have cracks (this causes the "too much green"), What you are saying indicates that the blue gun is intermitten, and the solder joints on the CRT socket itself (blue cathode) or the blue output transistor have probably cracked loose. once again, all you have to do is resolder it in place to ensure that the CRT sockets are mounted, and that will solve your problem,
The CRT socket is located behind it near the audio or video input.
hope this helps
Posted on Jul 28, 2008
    Scholar:
  • 101 Answers
You will probably have to replace both convergence chips (there are 2), this tv has an auto-convergence, and they get really hot and sometimes burn out. Use thermal compound on the heatsink to avoid this happening again.
Posted on Jul 23, 2008
  • 2,323 Answers
The failure in you TV is the convergence STK ICs. This might be a DIY project by swapping the assemblies.
Click here to find the assembly you need to fix your TV. Keep in mind that even after replacing the convergence board, you might still have to perform some alignments.
  • 10,594 Answers
Your TV has weaken capacitors in High Voltage area, speacialy in drive stage of Red Gun. Can you tell me how old is your TV?
    Master:
  • 382 Answers
This is actually a convergence problem,which could be caused to due over flow of current or power surge which might have affected your circuit board TV..First try the Hard reset..Try to Unplug the Tv for 1 or 2 hours and then plug it and check it!..If that doesnt work then check your circuit for any burnt Ic's or resistors or for any short circuit..Hope this helps you out..!!..Thank you...
Regards!!..
  • Natesan Sabesan
    Natesan Sabesan Jul 23, 2008
    Call a Service person or take your Tv to any nearby Service store to get it Repaired!!...
    Guru:
  • 1,894 Answers
Does it seems red convergence problem?
    Master:
  • 848 Answers
This looks like some dead pixels in your television ..........
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Hitachi 51GWX20B 51" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
How to repair a samsung rear projection tv
your power supply is getting weak
Aug 25, 2008 | Televison & Video
How much would it be to repair our t.v.?
The convergence chips have gone out. It costs about $300 if it's not under warranty. This is a common problem with all rear projection tv's.
Aug 10, 2008 | Samsung HCM553W 55" Rear Projection...
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
