SOLEUS LX140 UNIT DOESN'T EVAPORATE THE CONDENSATION AND LEAKS ONTO FLOOR
  • 1 more comment
  • Anonymous Aug 22, 2008
    Soleusair LX-140 leaking water emergency Tank Full but unit does not shut down
    Soleusair LX-140 leaking water on the floor. Emergency Tank Full but unit does not shut down. How do I check to see if water is leaking before it gets to the tank
  • acwoodworkin Aug 30, 2008
    Water condenses on the outside of my LX140 portable A/C. I have it draining to the outside already. I put a drain pan under it to collect the condensation.
  • 143 Answers
You need to get the condensate water to drain outside the building.
Posted on Jul 25, 2008
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
What is causing water to leak down onto the floorboard of my 2004 Mazda 6 when I have AC on?
this will be condensate from the fins of the ac evaporator in the car and is leaking onto the floor because the drain on the unit is blocked either in the hose or at the bottom of the ac box
Aug 24, 2014 | 2004 Mazda 6 Wagon
I have a soleus pe2-10r32 portable a/c and it is leaking out of the back of the machine but not all the time! i put a drain hose out of the drain port so it can drain into a bucket that worked fine for a...
This is your condensation build up on the A/C unit. You will have to have a drain on it all of the time. Should have a drain that goes outside. The more humidity the more water run off you will have.
Jul 21, 2014 | Soleus Heating & Cooling
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Leaking all over the floor
If it's a window unit, it needs to be tilted down on the outside a little; there may be a drain plug that you should open also. If it's a portable unit, you'll need to check the drain pan and/or drain hose. The water is condensation created by the unit doing it's job; it needs to go somewhere.
Jul 18, 2011 | Soleus Heating & Cooling
Undercounter Sub-Zero leaks onto floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 14, 2009 | Refrigerators
Soleus LX-140 leaking problem
We have a 1-year PE3-09R-03 that just started dripping water on the floor. The red "tank full" light never came on. I opened it up to investigate, and I believe the problems are caused by dust. The plastic float that trips the "tank full" switch appears to have gotten stuck due to the combination of water and dust in the tray. Once I loosened it up and cleaned the guide tube it rides in, it would trip the switch when the tank was full. The reason the tank was filling up was a little less obvious. There is a 2-piece plastic tray that sits underneath the evaporator and above the condenser. The tray is supposed to distribute the water that's dripping from the cold evaporator coils onto the warm condenser coils so it can evaporate and be blown out with the warm exhaust air (note that "evaporator" and "condenser" are referring to the refrigerant - the terms appear backwards when referring to what's happening to the water on the outside). The tray and its lid have a series of tiny holes that were - guess what - plugged by dust. The tray is relatively easy to remove, just two screws and a spring clamp on the overflow hose. The tray lid is heat-staked onto the tray, you should be able to clean it without separating the lid. I cleaned and reinstalled the tray and verified that water would flow properly. I then reassembled the unit and fired it up, and it's been running without a puddle for over a day in humid weather.
The unit has a filter for the recirculating room air, but there is no filter for the outside air loop. Adding a filter would obviously help keep the dust out, but it could also reduce the cooling efficiency of the unit.
DO NOT use one of these on a floor you care about without some sort of emergency catch tray underneath!
Jun 09, 2008 | Soleus KY-34 Portable Air Conditioner
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
