Question about AudioBahn A8002T Car Audio Amplifier
Audiobahn A8002T Same problem as everyone else. but now my amp wont get out of protection mode. i checked all wires and fuses. i have 2 12" infinity 1252w hooked up to the amp bridged. 1.5 capacitor and 150amp fuse holder.
  • 631 Answers
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Let me know if you have any other questions.
Posted on Jul 23, 2008
Bumps good but every 10-15 min of bumping it
to much power hooked up to it take something away
Jul 21, 2010 | AudioBahn A8002T Car Audio Amplifier
My amp is stuck in protection mode, what are some solutions to this
That indicates a short. Either inside the amp or the speaker wires or the speaker themselves are short. Remove the speaker connection if it is still in protection mode then you have an internal short. You can reset these they are there to prevent electrical fire. The only solution is to find the short and fix it.
May 13, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
Audiobahn A8002T wont turn on
try the power wires make sure they r grounded properly or won't work
Jun 29, 2009 | AudioBahn A8002T Car Audio Amplifier
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
I need a diagram for my A8002T Amp anyone have one?
check out audiobahn.com thier is a free wiring diagram under tech support
Mar 22, 2009 | AudioBahn A8002V Car Audio Amplifier
AUDIOBAUN A8002T Car Audio
add doide from the battery to the unit, 2 doide should help that.
1 connected to the positive, an 1 connected to the negative. 5-10 amperes is ok. check for the polarity. and try to take off the ground of the unit then try it.
Jan 15, 2008 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t has no sound
if you are getting amp lights to turn on at all, then power is getting to the amp so although the fuse is oversized (50 amp fuse ok), it is not your present problem. I am guessing the final stake transistors have failed. do you know how to test them...you can use a multimeter that has a transistor test function, but first de-solder two of the 3 pins from the pcb...be aware that power MOSFETS may exist that cannot be tested with this meter.
Aug 10, 2007 | AudioBahn A8002T Car Audio Amplifier
AudioBahn A8002T Car Audio Amplifier Logo
349 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
