Question about Brother HL-2040 Laser Printer
My Drum was replaced last week yet the light will not go off. So this means that we can not print on our 3 month old HL 2040 laser printer
Did you do the drum reset procedure when you replaced the drum? It was on the sheets of paper (aka instructions) that came with the drum unit.
Posted on Aug 20, 2008
What might cause my Brother HL-2040 to leave black blotches and an overall gray appearance on print outs?
if your drum is new and still you are getting a problem of dark background then you have to replace the toner cartridge.
Jul 26, 2014 | Brother HL-2040 Laser Printer
Faint print on Brother HL-2040
Try cleaning the drum cylinder with alcohol and a cotton ball. Then swipe the corona wire cleaner back and forward making sure to return it to the correct place. Try a print. If it is improved - replace the drum at earliest convenience. If not improved - could be dirty laser lenses or problem with the fuser.
Oct 20, 2017 | Brother HL-2040 Laser Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Drum light blinking
The light blinking means it's almost used up, when it comes on solid it will stop printing. If your prints still look good you can open the front door and hold the go button til all lights flash, and it will think it's a new drum. You can replace then when print quality gets bad.
Jan 06, 2010 | Brother HL-2040 Laser Printer
Drum light on will not print
its possible its not hooked up to your default current printer... try going to "start" then "settings" then "printers and faxes" then look for your printer name that you want to print with ex: Brother HL-2040 Laser should be there :D hope it helps
Jul 27, 2009 | Brother HL-2040 Laser Printer
Printer prints a duplicate image. Is the drum dirty?
does the problem exist if you try your old cartridge (just for a test)? if it doesn't, then you have a defective toner. Otherwise it is coincidental, and you need to replace the Drum unit.
Mar 09, 2009 | Brother HL-2040 Laser Printer
DRUM LIGHT KEEP FLASHING
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
Brother hl-2040 printing problem
Could be that there are a mark on the drum itself or some dirt, remove the drum unit and inspect the surface , by rotating the drum , becareful not to touch the drum as it will leave marks on the surface
Apr 25, 2008 | Brother HL-2040 Laser Printer
BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Apr 06, 2008 | Brother HL-2040 Laser Printer
Drum Light
The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. please see my other post. as for not picking up give the feed roller a clean with metho and a rag, rubber roller under machine with cassete out it's about an inch wide and black.
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
693 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
