Question about Hoover Washing Machines
Nextra HNF 6127 not spinning and full of water
The machine is not spinning properly, the clothes are all wet, I have removed the filter to clear any debris and water just keeps pouring out of the filter compartment
Trifect7
  • 57 Answers
SOURCE: hoover nextra hnf 3671 -
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord if you feel qualified.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Posted on Mar 02, 2008
SOURCE: Water leak at rear of
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Posted on Jul 30, 2008
barkencoa
  • 3463 Answers
SOURCE: my hoover optima machine model
Check to see if it is on rinse hold or crease care, if it is this will cause it to stop at the rlnses, also ensure that tjhere is cold water at the valve, a faulty cold inlet valve will cause it to stop,as it will be waiting for cold water.
Plz rate my solutioun.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: my hoover optima washing machine
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover HNF 2137 - Machine washed clothes but did not drain them, then when I tried to put on a new wash cycle no water filled in the machine, any help please?
'....but did not drain them...'
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 24, 2011 | Hoover Nextra HNF 2137 Front Load Washer
My washer will spin but my clothes still come out soaking wet and with some water left in the drum
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
John C
Sep 01, 2011 | Hoover Nextra HNF 3157 Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
My hoover hnf3157 machine spins briefly after a wash leaving the clothes still sodden. When it goes to a high speed spin it lasts about 5 to 20 seconds then stops. I have to do a separate spin to finish...
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Jun 01, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
