Question about Pioneer SD-643HD5 64" Rear Projection Television
Daytek dt 3220 will not power on - Pioneer SD-643HD5 64" Rear Projection Television
  • Anonymous May 04, 2009
    i have the same tv for few years now...remote control had died down on me
  • 286 Answers
OK, your Daytek 3220 is not a projection TV, but an LCD TV.
Second, I hate to say it, but you bought a piece of junk. They have excellent pictures when they're new, but after a few years capacitors in the power supply go bad. When this happens, either the controls and remote stop working, or the TV starts blanking out, or it will just die and never work again.
The solution is to go buy a new TV. The power supplies are no longer available, and even if you could get one very often the faulty power supply has damaged the main board and/or the LCD panel.
In about 5% of these cases, replacing the capacitors will get the TV to work, in about 25% it will get the TV to work, but because the main board has been damaged the TV will intermittently blank out. In another 25% the LCD panel has been damaged so once repaired you will see dark streaky patches across the display.
In the rest of the units you could have all three problems or any combination of them.
It'ds really too bad because they use a Samsung panel, and have excellent pictures when they're working.
Posted on Dec 17, 2008
Daytek 46" LCD TV.. When
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Jun 09, 2011 | Televison & Video
Hello all ! My 42 inch Daytek TV is broken. I tried everything to fix it but.... no success. I know which PCB is defective but i cannot find a replacement part for it. Daytek doesn't sell parts anymore...
Hi mojo_686,
If you can't find the exact part for your Daytek TV in a local store or repair center, I recommend to contact the manufacturer directly. If system is still in warranty they will set up a free service and repair for your unit. Please click the link below for the complete contact information of Daytek.
Daytek Contact Info
Hope it helps.
Thank you for using FixYa.
Mar 24, 2011 | Televison & Video
I have a Daytek air conditioner and it is giving the following error message E3 What is the problem and how do I fix it thank you
E-3 means indoor motor mechanism locked or no power to motor.Check& rectify motor and PCB.
Jan 11, 2011 | Heating & Cooling
I have EnGenius EOC-3220 (EOC3220) i can not reset with my null serial cable please help me
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Aug 12, 2010 | EnGenius EOC-3220 (EOC3220)
Daytek DT-3220 power problem
I have just fixed the power problem on my Daytek 3220. It looks like the Bentek BP-200AD power supply is used in other cheap brand TV's besides this Daytek : Hyundai HLT 3280, Jwin JV-DTV3212.
At first, my TV would just lose the backlight, while the video and sound would still work fine. Power cycling the tv would correct the issue, but would repeat the problem after shorter periods of time.
More recently, I've started losing the video and audio, shortly after backlight.
I have checked all the caps on the outputs and they all tested ok, using capacity and ESR meter (surprisingly enough) and no bulging either.
This power supply outputs 3 voltages : 5V, 12V and 24V, with a stand-by control pin on the 5V connector (0V for TV on and 5v for tv off).
I have got the readings after the power died:
5v out= 5v--ok
12vout=0.72v not ok
24vout=0.0v not ok
One of the transformers was squealing quite annoying while tv worked, but started modulating the squeal a couple of seconds before power died.
The culprit : one small electrolytic capacitor marked C19 on both sides of the board, with a value of 47uF/35v. I have replaced it a 56uF/50v and the TV started working as new (and of course no more squealing either).
Use a good quality cap when replacing C19. A 50v rated one would be a better choice than the original 35v and make sure it is also rated for 105 degrees Celsius, since it is very close to one of the heatsinks.
As always the DISCLAIMER: take all the precautions to avoid electrocution. Disconnect the TV from power, allow a few minutes for the big 400Volt capacitors to discharge completely, before handling and working on the power supply.
Feb 13, 2010 | Televison & Video
I can not find remote codes for the Daytek DVK-5601 DVD player
Well I finally got an answer from Daytek. It's not what I wanted to hear, but thought I'd share it in case someone else runs into the same issue.
"I am sorry to inform you that theres no dedicated universal remote code for Daytek models. However, you can try the code for MTC on our unit and see if it works."
Apr 08, 2009 | Televison & Video
I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
Oct 31, 2008 | One For All URC-3021 Remote Control
On Daytek LCD DT4040, After some time like 2-3 hour, sometime 10-15 minutes, image from source disapear and red and green line appear... Not actually on DVI input, no trouble since 30 minutes.. on test for...
i have a daytek dt 4040 and when i turn it on,i push the red button ,flash 5 or 6 time and turn green have sound but no image. what the problem
Aug 19, 2008 | Televison & Video
Get addvice
This is a good one!
Did you ask the dealer where you bought the set?
Did you enquire about the local Daewoo service rep for your area?
If the above is not useful, I would do a Google search for other news groups and sites that deal with Daewoo.
Daewoo Contacts below:
Daewoo Daytech consumer and industrial for North America:
http://www.daytek.ca/contact.html
Daewoo Corperate World Wide Info:
http://www.daewoo.com/english/index.jsp
Jerry G.
Apr 13, 2008 | Televison & Video
Pioneer SD-643HD5 64" Rear Projection Television Logo
1,506 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
