Question about Dell 922 All-In-One InkJet Printer
Paper jam error message, was no jam, then printer wouldn't work
Printer was working fine, then I went to print another item and the paper jam error came up. Opened printer up and there was no paper jam, closed printer and sounded like paper was rolling through kind of fast, but nothing was happening. No paper was feeding into the printer. Have not been able to use it since. Can you help me please? I finally gave up and my son brought me another printer from his office, but I miss and NEED my scanner and fax with my all-in-one.
Like others, I called Dell and was told that since my warranty had expired I would have to pay for support help. What a racket they have! I'm not sure how this site works as to how to find answers to the problems I've seen, so I will give you my email address. It is Would appreciate any and all help you can give me.
  • Anonymous Jul 23, 2008
    Have this problem. Printer says paper jam turn off printer and clear jam. We have done this several times and there is no paper jammed in the printer. Same message appears paper not running through printer you have to feed paper in and it takes it very quickly but not printing. Can anyone help????
  • 36 Answers
I think that your problem is that there is a tiny piece of paper stuck in the printer.
Usually this happens when you get a paper jam and you rip, not pull the paper out.
Make sure everything is clear and out of the printer
Hope this helps you.
Posted on Jul 23, 2008
  • Dell Master
  • 1,183 Answers
You can use the following link to troubleshoot you issue
  • 446 Answers
Chances are there is still some residual piece of paper stucked somewhere in the paper path, which prompted the unit not to operate, or the sensor was dirty and blindly recognize any unwanted object, mke sure also that the trays are seated correctly and there is no obstruction in any of its path, try this first, dont loose this valuable unit...
Posted on Jul 25, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ... Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ... Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ... There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ... > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
Error message paper jammed on my printer but there is no jam. my color ink is out but i don't use color
when it happen like that turn off the printer, print anything, open the active printing file. it will show u the jam paper and the current printing one. cancel the spoonling paper, after cancelling put on the printer and it will work fine
Sep 13, 2010 | Canon PIXMA MX310 All-In-One Printer
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
Error Message: No Paper, Load Organizer....................
Opened "Control panel>printers/faxes>Printing preferences>Basic>Paper source, and selected Tray 1 for all pages. Then went into the print menu in Adobe Reader, wich is where I was trying to print from originally, and deselected "choose paper source by PDF page size. It seemed to work.
Jul 18, 2009 | Brother HL-4070CDW Printer
Print error
remove your cartdgwe thwen powr up.
check there is not any paer jam.
Nov 18, 2008 | Office Equipment & Supplies
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
"Clear paper jam" error, but there is no jam!
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
