Question about RCA Televison & Video
RCA 32F530T I HAVE A 32 RCA WHICH NEEDS A FLYBACK TRANSFORMER AND WAS TOLD IT WAS NO LONGER MANUFACTURED IS THIS SO?
    Sergeant:
  • 280 Answers
No you can get a replacement from Suburban Electronics
1-800-341-5353
Give the model number or if you can fine the CTC # they can get you a sub for around $18.00 plus SH
Posted on Jul 23, 2008
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
Why won't my T.V. turn on?
hello . it sounds like a high volatge problem . the tripler and the or the fly back transform. is bad. and thats what is huming. sound that you hear. time to get a new set. Good luck
Feb 08, 2009 | RCA 32F530T 32" TV
RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
May 29, 2008 | RCA F32650 32" TV
RCA 32F530T
It could be several different things wrong, need to know if transformer {you think} has a big heavy insulated red wire coming out of it going to the picture tube, if so; that is the high voltage transformer. You will need a schematic to check out some capacitors, and transistors....the three areas would be problems with capacitors in power supply, the B Plus Regulation circuit, and check for rings around joints in that and overall on the main board and any connector joints that attach other modules to it, or plug into it, as well as joints associated with all plugs from wiring harnesses as well. Just guessing, sounds like a power supply regulation problem, and or joints that are ringy, rings around them or cracked ones. Hope this helps. T.
Jan 14, 2008 | RCA 32F530T 32" TV
TV won't turn on...
Probable bad flyback transformer or shorted cap in horiz circuit,
horiz output xistor suspect,also...................have tech check or
replace set....................T.
Dec 03, 2007 | RCA 32F530T 32" TV
Substitute flyback transformer 257805 causing skewed picture on flat screen
you have a pin cushion problem Checking the resistance to ground at DL04(K) found it was 8 ohms. Disconnecting the Pin modulator board at connector HL83 cleared the 8 ohms indicating the 8 ohms was caused by the Pin modulator board. Closer observation a capacitor CL85 a 6.8 mfd electrolytic, finds it to be vented and it was causing the 8 ohm short. Replacing HL85 pn 238292. This corrected the symptom.
Nov 07, 2007 | Televison & Video
Switch mode power supply not switching and buzzing when powered up.
Common failure " buzzing " cause = bad flyback transformer
& horiz output transistor = replace both at same time.......
part # 's 257807 & 237470 RCA only No sub's.........T.
Oct 31, 2007 | RCA 32F530T 32" TV
Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Oct 30, 2007 | RCA 32V550T 32" TV
Won't work
It sounds like something in the high voltage (flyback) circuit failed. If any little thing shorts in these RCA's they will not start up. Stargazer
Apr 15, 2007 | RCA 32F530T 32" TV
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
