Question about Encore ENH908-NWY+ 8-Port Nway Switching Hub (ENCOREENH908NWY)
Compatability problem I have verizon dsl and they do not support your router, ENH908-nwy+. I need to know what to do to make them work together. My vista computer works but my XP cannot get on the internet
  • 20 Answers
The router that you're using, is it also your modem, like a gateway (modem and router in 1)? I need more info to help you out here.
Posted on Jun 22, 2009
Is the power input center pin + or - on the ENH908-NWY?
Try contacting the manufacturer.
Or, if the old AC adapter still works, it might be written on it. If not, try it with a multimeter.
If you don't have a multimeter, you can ground one contact of a light bulb and with the other contact see where the current is coming from (know that this is completely at your own risk: don't experiment with electricity unless you really know what you're doing!!)
Dec 01, 2013 | Encore ENH908-NWY+ 8-Port Nway Switching...
Theres an ip address conflict when i use my 8 port NWAY switch
You need a router to use the hub or switch. It provides the IP routing. Make sure the Router is set DHCP. If you have all this correctly setup then try:
Go to Start > Search (Run in XP) and type cmd and hit ENTER. In the command prompt type ipconfig /release and hit ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it.
Dec 10, 2012 | Encore ENH908-NWY-A 8-Port Nway Switch
No puedo conectarme con el rauter, no tengo los driver
Hubs don't require drivers. They simply connect via RJ-45 with a Cat network cable.
No necesitas drivers.
Nov 25, 2012 | Encore ENH908-NWY 8-Port 10/100Mbps RJ45...
How do i turn off the router portion on my d-link 2750
Make sure ASUS modelRT-N13U wireless router is turned on then unplug your new router wait about 30 seconds then plug it back in.
It should find your wireless router.
Here is a web site with more trouble shooting advice:
https://www.asus.com/Networking/RTN13U/
Hope this helps
Feb 09, 2018 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
Can the microsoft MN700 Router be used with cable internet instead of DSL from the phone company?I switched from Verizon DSL to Comcast Cable internet but can not find an answer if the MN700 is compatible...
I would say yes but i have not tested it personaly, but what i know about routers it should work with. Cable internet and dsl are exactly the same thing. The only difference is how its delivered to your house and the speed of it.
DSL tands for "Digital Subscriber Line." It is medium for transferring data over regular phone lines and can be used to connect to the Internet
cable the same thing except it is internet though the cable line. you u run the out of your
you probably wont even have to change any settings on it either. the line out of the back of your cable modem will plug into the same spot the old cable ran to when you just had dsl.
if this has been helpful please mark it has fixya. also please rate me, and if you have found it very helpful or informative please recommend me.
Nov 16, 2009 | Microsoft MN-700 Wireless Router
Reconfig 327w to work with Hawaiian Telecom DSL
try this launch IE go to tools internet options, connections tab, remove all the dialup.
this will fix the verizon connection problem.
Oct 09, 2008 | Westell Wirespeed VersaLink...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
