1997 GMC Jimmy Logo
A
Anonymous Posted on Feb 11, 2011
1997 GMC Jimmy 4.3. It runs great. I will drive it for 30-45 min and then it will die on me. All dash lights will come on just like if you turn the key on and not start the engine. It will restart and then do it again in a few minutes. It will eventually die and will take longer to start. All the interior accessories work and all dash lights and gages work. You will then hear the relays and fuel pump come on and you can start it again. Then it will die again in a few minutes, let it set with key on for a while and the relays will click and you will hear the pump come on and it will start. At the same time you cannot link your scan tool until the relays and pump come on. No DTC codes are present. Its driving me nuts.
H smith
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Feb 11, 2011
H smith
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4991
Points
31
When the engine dies do the accessories such as radio, lights, heater all die along with the engine; or do they keep running as they were prior to the stall?
If they all quit together (as if the key was shut off) I would check the electrical part of the ignition switch or the battery cables and connections (check both ends of cables and little ground wire near battery that connects to car body). The ignition switches are a well known culprit in the s10's.
If the radio and lights keep running after the stall, I would look at the crank position sensor, ignition coils etc.
Good Luck!
I have a 1998 GMC Jimmy, put a different engine from a 1996 gmc jimmy in it, its been running great and here about 2 weeks ago it started giving me problems, I put the key into the ignition turn it to...
the signal flashing is a bad hazard switch. they all brake. if you hold the flasher buton just the right way the noise stops. sounds like your dash is shorted with the flasher
Why would my jimmy cut off sometimes while driveing and than run fine after sitting for a few minutes
im not sure but my jimmy will run great then i go to the store and come back out it wont start i wait 15 min and it starts right up , my problem was security sensor , see if the security light comes on when it happens if it does i would look into that
1997 gmc jimmy starter motor not turning
You need a better battery. When you hook the amp meter and read 0.3 the ECM needs to sleep
My Jimmy is having problems with starting if I turn the key it does not run until the dash lights come on but the dash lights don't come on all the time I hit the computer and then pulled on the wires...
Common Problem on the Jimmys, and Blazers is the ignition switch wiring Harness. The Engine will crank, you can try many times, then all of the sudden the dash lights come on , and the guages all work, it will start. I Have seen this problem 4 times, in my years of being a mechanic.
2answers
How to change heater core on a 97 jimmy
when i turn on my heater it kick out after a few min then come back on or sometimes not at all on my 97 jimmy 4x4
My 1997 jimmy just dies and then I get no dash lights so it won't restart. Is this an electrical problem? Is it in the key switch or the steering column?
sounds electrical .. could be the electrical part of the ignition switc which is located on the steering coloumn...simple to locate the wiring harness coming from it... can you wiggle the key to simulate this problem
1helpful
I have a 99 GMC Jimmy with the 4 wheel drive. I
check fuse and relay to switch if power to switch retest switch new doesnt mean not defective if no power check connections and wiring for damage or breaks
1997 GMC Jimmy SLS * * #4 Fuse (gage panel) keeps blowing. Replaced the battery, ingnition switch, alternator. There is a winding sound before it blows (was told its related to 4 wheel drive). Out of...
haveing the same problem 1997 jimmy doing the same exact thing i got wire digrams for it still no luck so if anyone know whats causeing please help
Dash Gages
bad altenater or short in wiring
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
